Full Version: Estuary MOD V2 - KODI 18 (UPDATED 17/01/19)
(2019-03-20, 23:40)the_other_guy Wrote: [ -> ]
(2019-03-20, 17:11)minori_aoi Wrote: [ -> ]
(2019-03-20, 15:27)vertex Wrote: [ -> ] custom Main Menu functionality only? Basically I only want to separate my Adult Movies from regular Movies and Anime Movies. And separate regular TV Shows from Anime TV Shows.
nodes then link to menu
https://kodi.wiki/view/Video_nodes
xml:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<node order="40" type="folder">
 <label>744</label>
 <icon>DefaultFolder.png</icon>
 <path>sources://video/</path>
</node>
<node order="40" type="folder"> change number
<label>744</label> name
 <icon>DefaultFolder.png</icon> icon image the same as link
drive:Adult Movies
drive:regular Movies
drive:regular Anime TV
I'm sorry, but did you meant to do it on stock Estuary skin? Please elaborate more. I've read Kodi documentation about that, but still can't achieve what I want. This skin can do exactly what I want with the home / main menu, but I don't like other part of the skin, like the OSD and Media Information.
Is Guilouz still here in the Forum?
is it possible to reduce the size of icons?
i use widget appearance as posters panel.
i can only see 4 movies in each row.
is it possible to reduce the size so that we can fit more posters but also must be able to see movie name
(2019-03-31, 21:07)m2k1980 Wrote: [ -> ]EDIT: Got it solved. i forgot the holiday settings to turn off
Where is this settings ?
(2019-04-01, 19:08)Vision_rc1 Wrote: [ -> ]Is Guilouz still here in the Forum?
I also wonder ! No updates anymore. Has he left the scene ? It would be nice if he would let us know if development of this great skin has finished.
(2019-04-02, 00:54)lkemot Wrote: [ -> ]
Settings/extras/enable themes.
(2019-04-01, 13:48)minori_aoi Wrote: [ -> ]
xml:
 <label>744</label>
</node>
drive:Adult Movies
this is how you make a Categories widget at the top of the page just use library node editor
(2019-04-01, 23:19)bittihuduga Wrote: [ -> ]is it possible to reduce the size of icons?
not with out doing some edits to xml files
 Includes_Home.xml
View_54_InfoWall.xml
https://forum.kodi.tv/showthread.php?tid=313428
Sorry folks that I don't have the time to read more than 4100 replies in this thread....
I guess that Guilouz made some changes within the last two years, so I would like to know if there were developments regarding editing the main menu. Can I add new items there (as a node) ? Other skins can do that, but not Estuary without mod.
I tried to do that as described here in the Kodi.Wiki for adding Concerts, but that doesn't work for me since it's not updated to Kodi 17.6 or 18.x
(2019-04-02, 15:52)tom.58 Wrote: [ -> ]Sorry folks that I don't have the time to read more than 4100 replies in this thread....
Yes you can add your own items.
(2019-04-02, 19:45)Harro Wrote: [ -> ]Yes you can add your own items.
Thank you, looks good !
Is it possible to directly add a separate content to these new items ? e.g. for "UHD Movies" adding a new source with uhd-movies (=movie content) without having this uhd-movies in the normal "Movies" item as well ? or do you have to set filter....?
(2019-04-02, 20:26)tom.58 Wrote: [ -> ]
I have my UHD, 3d and UHD Tv all as individual sources. I then set content but exclude from a normal scan. This way I scan manually for UHD content without it adding to my current movie collection. But it will add them to sets/collections. So as an example I have Avatar in Bluray and also 3d. It made a collection with both of these movies under the heading Avatar collection.
(2019-04-02, 21:54)Harro Wrote: [ -> ]
thanks for sharing the screenshot which gave me the idea to do something similar.
I achieved the same with a favorite to a smart playlist that contains any 4K movie [emoji6]
I am really enjoying this skin so far on my Minix U9. Plays well  and is pretty responsive.
I also have a lot of the playlists that PatK made in the off topic discussion section, plus have made my own.
(2019-04-02, 21:54)Harro Wrote: [ -> ]... I then set content but exclude from a normal scan. This way I scan manually for UHD content without it adding to my current movie collection....
Thanks for this information. I need to add Concerts (as a movie) but don't want them to appear in "Movies", want them separate in a main menu item like "Concerts" as you did with "UHD Movies". Gonna try that way....
