Hi. I'm using the translator to help. Please.
If you press the movie button on the main menu, I hope the number index doesn't come out. It's on basic skins, but it's not on mod v2. Somebody help me Please
ex> movie title / 1/1334 <-- i need number index
I'd like it to look like the screen shot below, but it's inconvenient because it's not here. Somebody help me.
The picture is the basic skin of an extuary.
(2019-11-06, 20:15)wcndave Wrote: [ -> ]I have a problem with keyboard navigation when customizing the main menus.
The above picture shows a new menu item on the left, which has the "8 rows" widgets enabled, and the first widget is a parent node from video library.
However it is not possible to navigate to this with keyboard (and therefore remote).
I also added netflix, and had the same thing.
If I add them to the actual "movies" page, it all works fine, also TV Shows, however I cannot add to any other main menu item.
When using VNC and the mouse, it works, and in fact after that I can navigate with keyboard, however then I can't navigate OUT of the row....
Any ideas?
EDIT: added playlists as a widget, and also doesn't work on the videos main menu item. Looks like quite a few that don't allow navigation with keyboard. Hopefully it's a quick fix!
Same issue here.
When creating a new main menu item, and then adding widgets to it, navigating to other rows in the widget view is impossible. Only going right and left in the first row works.
It works when I add widgets to main menu items that I created some weeks ago.
(2019-11-10, 22:14)eurotrashgirl Wrote: [ -> ] (2019-11-06, 20:15)wcndave Wrote: [ -> ]I have a problem with keyboard navigation when customizing the main menus.
Any ideas?
Same issue here.
If you look at the XML for something you created before that does work, and the one you created now that doesn't, is there anything obviously different?
Hello, it's been a while since I last used Kodi (I think I used 17.2 last time I can remember...) and I really loved Estuary Mod's Horizontal Menu option, I much prefer it compared to the default vertical look.
I am now using Leia 18.4 with Estuary Mod v2 but I just can't find it anywhere... Was it removed? I really don't like the vertical style but love the modern look and customizability here.
(2019-11-13, 12:45)wcndave Wrote: [ -> ] (2019-11-10, 22:14)eurotrashgirl Wrote: [ -> ] (2019-11-06, 20:15)wcndave Wrote: [ -> ]I have a problem with keyboard navigation when customizing the main menus.
Any ideas?
Same issue here.
I already tried that, but was not sure which files to look at. Any hints?
Up to now I check in "~/.kodi/userdata/addon_data/script_skinshortcuts" the relevant xml files and the file "skin.estuary.modv2.properties" - without finding anything suspicious.
Please add codec and bitrate video information button on osd, same like in Rapier skin. Its very helpful for example on devices like Android TV without keyboard.
^I mean button on OSD to display "Ctrl+Shift+O" on OSD, not only "O" informations.
(2019-11-14, 21:48)eurotrashgirl Wrote: [ -> ]Up to now I check in "~/.kodi/userdata/addon_data/script_skinshortcuts" the relevant xml files and the file "skin.estuary.modv2.properties" - without finding anything suspicious.
Erm, not really the right person at all, however I thought this stuff was stored in /storage/.kodi/userdata/library/video
or is that only for the library navigation....
(2019-11-13, 22:24)eurotrashgirl Wrote: [ -> ] (2019-11-13, 12:45)wcndave Wrote: [ -> ] (2019-11-10, 22:14)eurotrashgirl Wrote: [ -> ]Same issue here.
addons\skin.estuary.modv2\xml
script-skinshortcuts-includes
what is sounds like is the widget list id and "group" id= do not match
<control type="group" id="5000">
<visible>String.IsEqual(Container(9000).ListItem.Property(id),movies)</visible>
all widgets would need to start with 5***
https://forum.kodi.tv/showthread.php?tid=344593
Hi
I'm trying to setup an Anime Movies main menu item with the widgets displaying only items from that source.
I've messed around with Library Node and smart playlists.
I can create the item on the menu, and clicking it does as intented, titles of movies from the node.
The issue is when its selected, I want the categories and widgets to appear, but only for that node.
Preconfigured widgets > Movies, shows all the movies.
Personalize Categories widget doesn't work how I thought it would work.
Video Library > AnimeNode > Recently added. This shows all recently added to movies...
Is this possible to setup in Estuary Mod?
Any help would be greatly appreciated.
(2019-11-19, 13:59)LegoMan79 Wrote: [ -> ]Hi
Many of these requests follow a similar generic pattern.
Have your own main menu items, which when selected result in a set of "rows of icons" on the main screen, which when selected do some kind of search - which can be done via smarlists, node editor, or both.
Then you want to assign your own icons for these things.
The problems appear to be that you can only assign icons to nodes, not to playlists.
Also, if you add a playlist row, and it has 20 items, you will have 20 scrolling off the screen, instead of a 5x4 layout for example.
Nodes allow custom icons, you can set the hierarchy to match your navigation needs, you can get them to display the results of playlists etc...
So that seems to be the primary way one could do this.
However as it's not possible to navigate between rows on custom main menu items, I am stuck.
So, I believe, that's how to do it, and why it doesn't currently work.
Given the skin mods are done free in peoples' own time, it feels a bit churlish to push for fixes. (of course so is Kodi...)
However I do think the main menu customization elements could be incorporated into kodi - main
(2019-11-19, 14:12)wcndave Wrote: [ -> ]Also, if you add a playlist row, and it has 20 items, you will have 20 scrolling off the screen, instead of a 5x4 layout for example.
If you want to limit this, set widgets to your needs.
(2019-11-19, 16:59)Harro Wrote: [ -> ] (2019-11-19, 14:12)wcndave Wrote: [ -> ]Also, if you add a playlist row, and it has 20 items, you will have 20 scrolling off the screen, instead of a 5x4 layout for example.
Right, but it doesn't wrap them at that limit, just cuts off.
I have a bunch of screenshots I did of what might be a good layout,
https://forum.kodi.tv/showthread.php?tid...pid2896489 particularly the 3rd one.
(2019-11-19, 17:04)wcndave Wrote: [ -> ]Right, but it doesn't wrap them at that limit, just cuts off.
I see what you are after and your correct about not wrapping.
Others may have some ideas for you.
