I am running Estuary MOD V2. Great skin.
Is there a way to get on the main menu Recently Added TV Shows --- like there is for Recently Added Movies?
I've looked everywhere and do not see that option.
When I started this morning my Kodi with estuary mod 2, I was surprised by a valentines theme.... I haven’t changed anything beforehand. Was this put automatically? Will it be put back automatically after valentine day again?
edit: nevermind. Found in skin settings under extras that there are holiday seasons themes. Cool feature
Will there be a KODI 19 version as it is released now? :O
Guilouz has been missing for a long time so iot looks unlikely any update will come from him. However there is a v19 comptible version available on the Kodinerds repo at
https://repo.kodinerds.net/
(2021-02-19, 21:23)jjd-uk Wrote: [ -> ]Guilouz has been missing for a long time so iot looks unlikely any update will come from him. However there is a v19 comptible version available on the Kodinerds repo at https://repo.kodinerds.net/
Nice works well. Thank you!
I'm using Estuary Mod on Kodi 18.9 and just out of curiosity I downloaded the Kodinerds Repo 7.0.1.1. to find out what's in. But under look-and-feel/skin, there are 3 skins available, but no Estuary Mod skin. Do I miss something ? Tnx.
It's great that it sounds like there is a version now available for Kodi 19! My devices haven't auto updated yet so everything is still working. So what will actually happen when they do update to V19? Will Kodi still run in some way with the old version of EM V2 thus allowing me to update it to the version mentioned above? I've got 5 devices running this that all took quite a while to customise etc and I really want to maintain the current setup without having to start again if at all possible.
(2021-02-21, 18:05)SirRickie Wrote: [ -> ] (2021-02-19, 21:23)jjd-uk Wrote: [ -> ]Guilouz has been missing for a long time so iot looks unlikely any update will come from him. However there is a v19 comptible version available on the Kodinerds repo at https://repo.kodinerds.net/
As you're still on v18 thenm you should be using the original Guilouz version from this thread, the version available on Kodinerds is an updated version for v19 Matrix only.
Thanks for the info , I downloaded it and installed it , seem to be working fine. I guess all future updates for this skin must be followed in kodinerds.
Let's hope that @
Guilouz come back with an official update.
Hi
Seems like I lost the next episode to watch under TV SHOWS menu, any Ideas?
Kodi Matrix , Estatuary mods V2 from kodinerds..
I think Skin.Helper.Widgets is missing, is this add on available for Kodi 19?
(2021-02-24, 22:09)Angelinas Wrote: [ -> ] (2021-02-23, 03:46)MAX404 Wrote: [ -> ]Hi
https://github.com/kodi-community-addons...master.zip
and needing module(install from zip...this first)
for rest of script read this thread...
https://forum.kodi.tv/showthread.php?tid=235676
Angelinas first of all , lots of respect for all your work !!
I already followed the thread you mention , still does not work , so far what i have done
Updated kodinerds mod to matrix3
Flashed all this , from post
4,204 and again after your post
4,240 , installation went fine only this one gave me errors
script.skin.helper.backgrounds.zip ,
Kodi.old.log ,
Kodi.log around 18:20nish
Also installed script.module.thetvdb , went fine no error
In script.skin.helper.service and script.skin.helper.widgets information / dependencies y can see script.module.
beatifulsoup not beatifulsoup4 , is not available
Tried to configure the widget from "home menu" customize , from skin.helper /episode/ next episode , the folder is there with the right information is just that i can get it to display the widget in the Home Menu / Tv Shows
Running out of ideas.....
First from log I see that you use script and module from zip....
I wrote in thread that user need to manual download from git hub and test.
Some error are fixed in github ...
Your error was fixed with this changes
Error in your log
[syntax=ERROR : JSONRPC: Failed to parse '{ "jsonrpc": "2.0", "method" : "VideoLibrary.GetTvShows", "params": b'{"properties":]ERROR <general>: JSONRPC: Failed to
you have was isue with JSON...that is fixed in new tvdb module
https://github.com/kodi-community-addons...7549ccaab2
Please reinstall all script and module from GitHub....some error will be fixed
script.module.cherrypy
script.module.musicbrainz
script.module.metadatautils
script.skin.helper.skinbackup
Edit :
one question ?
You use NVIDIA SHIELD Android TV with Android 9.0.0
can you see if you have code in folder for PIL....I see that you have
INFO <general>: CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
Some user report this module doesen't exist-work for Py3 (Android version) ?!?
BTW widget for Next Airing episode working
(2021-02-25, 18:35)Angelinas Wrote: [ -> ]First from log I see that you use script and module from zip....
Error in your log
Edit :
one question ?
Hi
oops my bad , will do re install the scripts and modules you mention here , question which is the latest repo,
repository.marcelveldt-1.0.2.zip?
No problem , I will check this afternoon after work , I will search for it , any idea where it is supposed to be?
I did not try that one , my problem is with
Next Episodes
plugin://script.skin.helper.widgets/?action=next&mediatype=episodes&reload=$INFO[Window(Home).Property(widgetreload)]
Provides a list of the nextup episodes. Searches for next episode after the last played, otherwise returns the first unwatched episode. Note: the reload parameter is needed to auto refresh the widget when the content has changed.
