I'm trying the skin with the latest 64 bit nightly for Android and I can't make it work. All I get after installing the skin is an empty home with only the background and the logo in the top left corner. Shall I install some extensions manually prior to installing the skin ?
Also a suggestion - I think it would be great if you can add the option to make the vertical menu slide out to the left when you focus on the widgets ... somewhat like the default android tv interface behavior. It can be done, since Arctic:Zephyr has it working very well.
(2017-04-27, 09:42)joro_abv Wrote: [ -> ]Hi,
You need to install addons from links in the OP
For your suggestion, I think it is already there:
Gracus - thanks, I haven't tried the skin in it's latest versions. Looks like it's there indeed. Will try it out, when I manage to make it work. Will install all required exts, before the skin and let's hope it will be ok.
(2017-04-27, 04:46)Guilouz Wrote: [ -> ] (2017-04-27, 03:55)ferent Wrote: [ -> ]Hi Guilouz, could you add Games support like the original stuary skin has? Or at least tell me how to create a new entry in the main menu to access it?
Note: if you can't see it in stuary is because you have to enable it in your guisettings.xml file.
Many thanks.
There is already games support.
But I can't try because when I enable games, it return always false when Kodi startup
<gamesgeneral>
<enable default="true">true</enable>
<enablerewind default="true">true</enablerewind>
<rewindtime default="true">60</rewindtime>
</gamesgeneral>
Thanks for your donation
EDIT : I use Konami code 'UP,UP,DOWN,DOWN,LEFT,RIGHT,LEFT,RIGHT,B,A' and it's working.
I think you have to stop the kodi daemon, delete the default="true" flag, set enable to true (like you have in your example) and start the kodi daemon again. I did that because I had the same problem (read the sollution somewhere in this forum) and is enabled now.
<gamesgeneral>
<enable>true</enable>
</gamesgeneral>
awesome skin great job, wish it would work on 17
(not a request)
extended info script leaves an open area in the bottom instead of going fullscreen. skin version 2.2.4 and kodi 18. any way i can fix this?
edit:
i removed script-script.extendedinfo-DialogVideoinfo.xml from /.kodi/addons/skin.estuary.modv2/xml and that seems to have fixed it, so there is maybe something wrong in that
(2017-04-27, 20:48)davidx Wrote: [ -> ]awesome skin great job, wish it would work on 17 (not a request)
(2017-04-27, 21:17)davidx Wrote: [ -> ] (2017-04-27, 20:48)davidx Wrote: [ -> ]awesome skin great job, wish it would work on 17 (not a request)
Working fine for me :
What resolution do you use ?
1680x1050
it seems that now when i removed that xml, the poster cuts off at the sides a bit, but it is full screen
New Update 2.2.5 on repository :
• Add games sources widget
• Add support for games artworks (artworks must be named identical to the file name of the game with the extension '.png' and must be in the same folder as games)
• Fix personalized widget 5
• Fix plots and thumbs on info dialog to avoid spoilers
• Fix widgets property
• Changes on widgets when libraries are not populated
(2017-04-27, 21:59)davidx Wrote: [ -> ]1680x1050
Because you don't have a correct aspect ratio.
How do I add games source widget?
(2017-04-28, 01:55)dnlg Wrote: [ -> ]Hi,
It appears when you add games sources.
New Update 2.2.6 on repository :
• Change extension file '.png' to '.jpg' for games artworks, like this :
• Minor fixes
Hi Guilouz!
Could it be possible to remove the colored border on movie cdart?
Seems like it causes issue with some of them:
(red ring inside the cdart)
(2017-04-28, 08:47)Gracus Wrote: [ -> ]Hi Guilouz!
Done on last git :
• Add possibility to disable colored outline for CDArts
• Fix disc overlay for some CDArts
