well that is the optimal resolution for my screen, you cant do it so it becomes resolution agnostic like exdended info? or have an toggle to turn off the dialogvideoinfo.xml?
its no big deal for me to go in the xml folder and disable it but it might become an isue when 18 comes to beta and more people start using it.
have to say though, it is BY FAR my favourite skin of any kodi version and i use your mod of kodi 17 as my daily. thanks for the hard work!
Hey Guilouz, anyway to add cdart to music and tv shows? The cdart is awesome, looks really cool.
(2017-04-28, 17:35)mack4999 Wrote: [ -> ]Hey Guilouz, anyway to add cdart to music and tv shows? The cdart is awesome, looks really cool.
There is no cdarts for TV Shows :
https://fanart.tv/tv-fanart/
And for music, cdart are provided by Skin Helper Service, it's use property and property not working in container, so it's not possible in some views, that's why I've decided to not included cdart for music.
(2017-04-27, 22:05)Guilouz Wrote: [ -> ]New Update 2.2.5 on repository :
• Add games sources widget
How do you get the icons from the different platforms (e.g. supernintendo) in the widget?
Hi Guilouz,
have also donated one or two minutes ago to show some respect for your great work on this skin.
At the moment I face a problem concerning my playlists. I can add tracks to a playlist and save it under the name I choose.
If I want to edit the playlist my screen looks like this:
watch gallery
Kodi shows the number of the tracks but nothing more. Can't open or edit anything - any idea what I could possibly miss?
I can create playlists via simple-playlist-addon but I would rather prefer the common playlists.
(2017-04-28, 21:44)Guilouz Wrote: [ -> ] (2017-04-28, 19:39)rudrood Wrote: [ -> ] (2017-04-27, 22:05)Guilouz Wrote: [ -> ]New Update 2.2.5 on repository :
I made them myself.
Yes, but how can I assign them to the added game sources?
(2017-04-28, 19:52)Epikur17 Wrote: [ -> ]Hi Guilouz,
watch gallery
Yes it's Estuary issue. I'm working on.
Another issue with playlist Guilouz happens when I add a playlist in the top widgets list of Music Videos. The playlist is there but if I click on it nothing is played. The error doesn't happen with the Party mode playlist.
I've reset the menu but no luck. Could you confirm if is an skin issue?
(2017-04-28, 17:12)Guilouz Wrote: [ -> ]Fixed on last git.
thanx! looks great.
(maybe another resolution thing?) i added some music and in the play screen the "lyrics source" text goes over other information.
when a live stream is buffering the little background will be just under the buffering bar.
(2017-04-28, 23:59)ferent Wrote: [ -> ]Another issue with playlist Guilouz happens when I add a playlist in the top widgets list of Music Videos. The playlist is there but if I click on it nothing is played. The error doesn't happen with the Party mode playlist.
With Skin Shortcuts In Personalize home menu ?
Yep, I've tested 2 different playlist, one generated by me, and one by the skin (made by you). This is the output:
01:34:05.659 T:139977235349952 ERROR: Previous line repeats 1 times.
01:34:05.659 T:139977235349952 NOTICE: VideoPlayer: Opening: special://profile/playlists/video/Nuevos videoclips.xsp
01:34:05.659 T:139977235349952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:34:05.660 T:139975680382720 NOTICE: Creating InputStream
01:34:05.664 T:139975680382720 NOTICE: Creating Demuxer
01:34:05.668 T:139975680382720 ERROR: Open - error probing input format, special://profile/playlists/video/Nuevos videoclips.xsp
01:34:05.668 T:139975680382720 ERROR: OpenDemuxStream - Error creating demuxer
01:34:05.668 T:139975680382720 NOTICE: CVideoPlayer::OnExit()
01:34:05.668 T:139977235349952 ERROR: Playlist Player: skipping unplayable item: 0, path [special://profile/playlists/video/Nuevos videoclips.xsp]
01:34:05.676 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:05.676 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
01:34:05.676 T:139977235349952 NOTICE: VideoPlayer: finished waiting
01:34:30.192 T:139977235349952 NOTICE: VideoPlayer: Opening: special://skin/playlists/random_musicvideo_artists.xsp
01:34:30.192 T:139977235349952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:34:30.194 T:139975995680512 NOTICE: Creating InputStream
01:34:30.201 T:139975995680512 NOTICE: Creating Demuxer
01:34:30.204 T:139975995680512 ERROR: Open - error probing input format, special://skin/playlists/random_musicvideo_artists.xsp
01:34:30.204 T:139975995680512 ERROR: OpenDemuxStream - Error creating demuxer
01:34:30.204 T:139975995680512 NOTICE: CVideoPlayer::OnExit()
01:34:30.204 T:139977235349952 ERROR: Playlist Player: skipping unplayable item: 0, path [special://skin/playlists/random_musicvideo_artists.xsp]
01:34:30.255 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:30.255 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
01:34:30.256 T:139977235349952 NOTICE: VideoPlayer: finished waiting
01:34:30.256 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:30.256 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
Of course, if I go to Playlist, select the desired playlist, right click and play, it's played with no errors.
