(2017-04-29, 02:35)ferent Wrote: [ -> ]Yep, I've tested 2 different playlist, one generated by me, and one by the skin (made by you). This is the output:
01:34:05.659 T:139977235349952 ERROR: Previous line repeats 1 times.
01:34:05.659 T:139977235349952 NOTICE: VideoPlayer: Opening: special://profile/playlists/video/Nuevos videoclips.xsp
01:34:05.659 T:139977235349952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:34:05.660 T:139975680382720 NOTICE: Creating InputStream
01:34:05.664 T:139975680382720 NOTICE: Creating Demuxer
01:34:05.668 T:139975680382720 ERROR: Open - error probing input format, special://profile/playlists/video/Nuevos videoclips.xsp
01:34:05.668 T:139975680382720 ERROR: OpenDemuxStream - Error creating demuxer
01:34:05.668 T:139975680382720 NOTICE: CVideoPlayer::OnExit()
01:34:05.668 T:139977235349952 ERROR: Playlist Player: skipping unplayable item: 0, path [special://profile/playlists/video/Nuevos videoclips.xsp]
01:34:05.676 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:05.676 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
01:34:05.676 T:139977235349952 NOTICE: VideoPlayer: finished waiting
01:34:30.192 T:139977235349952 NOTICE: VideoPlayer: Opening: special://skin/playlists/random_musicvideo_artists.xsp
01:34:30.192 T:139977235349952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:34:30.194 T:139975995680512 NOTICE: Creating InputStream
01:34:30.201 T:139975995680512 NOTICE: Creating Demuxer
01:34:30.204 T:139975995680512 ERROR: Open - error probing input format, special://skin/playlists/random_musicvideo_artists.xsp
01:34:30.204 T:139975995680512 ERROR: OpenDemuxStream - Error creating demuxer
01:34:30.204 T:139975995680512 NOTICE: CVideoPlayer::OnExit()
01:34:30.204 T:139977235349952 ERROR: Playlist Player: skipping unplayable item: 0, path [special://skin/playlists/random_musicvideo_artists.xsp]
01:34:30.255 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:30.255 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
01:34:30.256 T:139977235349952 NOTICE: VideoPlayer: finished waiting
01:34:30.256 T:139977235349952 NOTICE: CVideoPlayer::CloseFile()
01:34:30.256 T:139977235349952 NOTICE: VideoPlayer: waiting for threads to exit
Of course, if I go to Playlist, select the desired playlist, right click and play, it's played with no errors.
Just try two playlists, one with music files and other with music videos files and it's working. Have you selected 'Play' in choice when you have selected your playlist ?
Yep, are your playlist "Smart Video Playlist"? in your screenshots they have the m3u extension, but mine are xsp.
Could be that the reason?
(2017-04-29, 03:24)ferent Wrote: [ -> ]Yep, are your playlist "Smart Video Playlist"? in your screenshots they have the m3u extension, but mine are xsp.
Yes, not working with xsp files. Not a skin issue. Probably Kodi or Skin Shortcuts issue.
Hi!
The video lyrics are unable to show letters like á, é, í, ó ,ú and other ones.
Can you please add an option to disable the video lyrics? and show the old text lyrics with the cover and cd, or at least only text. I requested the same days ago and you said that is not possible, but at least if you point me what I have to modify would be nice, because is an annoying bug if you listen Spanish music and want to see the lyrics.
Thank you very much for your work making this awesome skin.
New Update 2.2.7 on repository :
• Changes for Kodi 18
• Add possibility to disable colored outline for CDArts
With colored outline
Without colored outline
• Add possibility to disable animated lyrics for classic lyrics
Animated lyrics
Classic lyrics
• Fix disc overlay for some CDArts
• Fix extended info window for some resolutions
• Fix playlists editor
• Minor fixes
(2017-04-29, 02:55)Guilouz Wrote: [ -> ] (2017-04-29, 00:15)davidx Wrote: [ -> ] (2017-04-28, 17:12)Guilouz Wrote: [ -> ]Fixed on last git.
thanx! looks great.
(maybe another resolution thing?) i added some music and in the play screen the "lyrics source" text goes over other information.
when a live stream is buffering the little background will be just under the buffering bar.
Fixed on last git.
thanks for you work! works great now.
Is voice entry on keyboard working?
Sent from my Pixel XL
(2017-04-29, 19:42)zenyatta80 Wrote: [ -> ]Is voice entry on keyboard working?
Sent from my Pixel XL (typie typie)
What ? Nothing to see with skin.
Guilouz, I signed up with an IPTV service and using PVR Simple Client. When using the EPG guide with your V2 skin I don't get the channel #'s just logos. However I do get them when using the default Estuary skin.
MOD V2
Default Estuary
Hi again Guilouz,
just updated and tried music-playlist. Saw there that you have changed something because I can see my playlist now if I want to edit it. Editing is still not possible - Can't add or delete a song - if I open any track titles vanish again. I guess you know that but wanted to give you a feedback from my system - mybe it helps.
Best wishes
(2017-04-29, 20:28)Repoman Wrote: [ -> ]Guilouz, I signed up with an IPTV service and using PVR Simple Client. When using the EPG guide with your V2 skin I don't get the channel #'s just logos. However I do get them when using the default Estuary skin.
MOD V2
Default Estuary
Yes, normal, I have replaced channel number by logo.
(2017-04-29, 21:12)Guilouz Wrote: [ -> ] (2017-04-29, 20:28)Repoman Wrote: [ -> ]Guilouz, I signed up with an IPTV service and using PVR Simple Client. When using the EPG guide with your V2 skin I don't get the channel #'s just logos. However I do get them when using the default Estuary skin.
MOD V2
Default Estuary
can i manually edit it, is so what file and locationn?
(2017-04-29, 21:11)Epikur17 Wrote: [ -> ]Hi again Guilouz,
Best wishes
Yes I didn't find how to edit playlist too but I have try with other skins (Confluence, Rapier, Titan) and it's the same. Maybe a change in Kodi 18 but not mentioned in Kodi 18 changes thread.
