(2017-05-14, 01:40)Gracus Wrote: [ -> ]Hi Guilouz!
Any way to get missing skin helper info (movie set plot, ....) from somewhere else?
Since there is no real way to get them again through skin helper service (API key reserved to dev)
There are no other addons able to do this to my knowledge...
(2017-05-14, 16:50)repulse Wrote: [ -> ]@Guilouz just curious about what solution you're using for pvr live tv ?
IPTV Simple Client and Tvheadend HTSP client.
(2017-05-14, 23:00)Gracus Wrote: [ -> ] (2017-05-14, 22:56)Guilouz Wrote: [ -> ] (2017-05-14, 01:40)Gracus Wrote: [ -> ]Hi Guilouz!
Was afraid of that...
Thanks for your answer
You can use your own API Key, I had a movies set that did not retrieve info and is now ok. I just try and it's working.
(2017-05-14, 23:52)Guilouz Wrote: [ -> ] (2017-05-14, 23:00)Gracus Wrote: [ -> ] (2017-05-14, 22:56)Guilouz Wrote: [ -> ]There are no other addons able to do this to my knowledge...
No API key for end users. Reserved to dev
(2017-05-14, 22:57)Guilouz Wrote: [ -> ] (2017-05-14, 16:50)repulse Wrote: [ -> ]@Guilouz just curious about what solution you're using for pvr live tv ?
Other question : is there a setting -or have you planned to add- a setting to auto show movie plot/poster when paused ?
Guilouz I love your skin, but I have a big problem with my music videos. Whatever I do: from all the music videos I have in one folder and add them to my library...only four seem to be accepted and show up. What are the criteria to be able to add music videos to the library?
(2017-05-15, 11:59)repulse Wrote: [ -> ] (2017-05-14, 22:57)Guilouz Wrote: [ -> ] (2017-05-14, 16:50)repulse Wrote: [ -> ]@Guilouz just curious about what solution you're using for pvr live tv ?
No, you just need to press info key to have info when paused.
(2017-05-15, 12:29)TaugenX Wrote: [ -> ]@Guilouz I love your skin, but I have a big problem with my music videos. Whatever I do: from all the music videos I have in one folder and add them to my library...only four seem to be accepted and show up. What are the criteria to be able to add music videos to the library?
You have not defined scraper for your music video :
And you must naming your files correctly. I use this structure :
So I tried again. I am really interested in finding out what I am doing wrong now or if there is a bug somewhere that can be solved.
https://vimeo.com/217491205
(2017-05-15, 14:54)TaugenX Wrote: [ -> ]So I tried again. I am really interested in finding out what I am doing wrong now or if there is a bug somewhere that can be solved.
Not understand... It's working now, no ?
There is no bug
You just hit the limit of using an internet database:
-a lot of your artists/group are not listed on audiodb.com -> these one will not be included in your library
-you must respect the name of artists and tracks: you got one video titled "theorie & praxis" when the real name is "theorie und praxis" -> probably those one will not be added to your library
As Gracus explained, the Library shows only content, which has been scraped (identified) correctly. If a scraper is not able to identify the file, it will not be shown in the library. This is how Kodi works.
(2017-05-15, 13:23)Guilouz Wrote: [ -> ] (2017-05-15, 11:59)repulse Wrote: [ -> ] (2017-05-14, 22:57)Guilouz Wrote: [ -> ]IPTV Simple Client and Tvheadend HTSP client.
So maybe you can point me to the right direction, for editing it myself ? I think it's in the VideoOSD.xml or maybe in in Includes_Home.xml but i can't figure where...
