(2017-05-25, 08:15)Epikur17 Wrote: [ -> ] (2017-05-22, 11:55)Guilouz Wrote: [ -> ] (2017-05-22, 05:00)Epikur17 Wrote: [ -> ]Hi Guilouz,
seems to be a missunderstanding - I have deinstalled artist-slideshow, so I don't use it either.
To your question:
Kodi is installed on c: - musiclibrary is located on f:
All my files are structured as in your description - if I change pngs for cdart Kodi shows the correct changes and then "forgets" them after one shutdown.
Paths are correctly set in artwork options "manualy change artwork" - Can't see my mistake - Is Kodi not able to read artwork if musicfiles are saved on a different harddisc?
Best regards
Try to delete or rename (to keep file) db from Skin Helper Service located here : Kodi\userdata\addon_data\script.module.simplecache\simplecache.db
Morning Guilouz,
tried that and Kodi reads my changes now - thanks for the hint.
Have also updated to your latest version - is the alphabet in the sidebar gone or do I miss something?
Best wishes
No, already there, in skin settings / library.
Hi
Can you update the thread's title with latest version and updated at dates? I suppose 2.4.0 is the latest version right?
Enviado do meu Nexus 4 através de Tapatalk
Hey Guilouz,
I'm getting the following message when loading Kodi:
INFO: Error loading includes.xml file (C:\Users\kodi\AppData\Roaming\Kodi\addons\skin.estuary.modv2\xml\Includes_PersonalizedWidgets.xml): Failed to open file (row=0, col=0)
I also have a request:
Is it possible to have a setting to set
path parameter for script.skin.helper.widgets widgets (like "next epidodes").
I have to manually edit my "skin.estuary.modv2.properties" file to filter my content by path.
Example:
['mainmenu', 'tvshows', 'widgetPath.2', u'plugin://script.skin.helper.widgets/?action=next&mediatype=episodes&reload=$INFO[Window(Home).Property(widgetreload)]$INFO[Window(Home).Property(widgetreload2)]'],
becomes:
['mainmenu', 'tvshows', 'widgetPath.2', u'plugin://script.skin.helper.widgets/?action=next&mediatype=episodes&path=nfs://192.168.1.77/movies&reload=$INFO[Window(Home).Property(widgetreload)]$INFO[Window(Home).Property(widgetreload2)]'],
This way, I can isolate widgets by path with the same content/mediatype (movies, tv shows)
Thanks in advance!
(2017-05-26, 01:23)redglory Wrote: [ -> ]Hey Guilouz,
Is it possible to have a setting to set path parameter for script.skin.helper.widgets widgets (like "next epidodes").
Example:
becomes:
Thanks in advance!
Includes_PersonalizedWidgets.xml file doesn't exist anymore in last release. You need to reset home menu item in skin settings and reconfigure. In next release, this will also be necessary too, I have changed many things and add more widgets.
For your request I can't do nothing, it's not related to my skin, it's a function a Skin Helper Service.
(2017-05-25, 22:28)redglory Wrote: [ -> ]Hi
I could do without any version number since I see that in KODI anyway. Less hassle for the dev, too.
No problem for me 😎 it's just easier to follow changes
Is it possible to have Favorites shown in a custom TV Shows widget?
(2017-05-26, 20:42)Dempsey44 Wrote: [ -> ]Is it possible to have Favorites shown in a custom TV Shows widget?
Yes it's possible with personalized widgets.
(2017-05-26, 21:16)Guilouz Wrote: [ -> ] (2017-05-26, 20:42)Dempsey44 Wrote: [ -> ]Is it possible to have Favorites shown in a custom TV Shows widget?
I've set my TV Shows to personalized widgets, but now to get Favorites to show up in widget 1 what do I set it to? I can't find Favorites as an option...
Thanks! Just updated to 2.5.0 and it looks great
(2017-05-26, 22:08)Dempsey44 Wrote: [ -> ] (2017-05-26, 21:16)Guilouz Wrote: [ -> ] (2017-05-26, 20:42)Dempsey44 Wrote: [ -> ]Is it possible to have Favorites shown in a custom TV Shows widget?
In Skin Helper Service widgets you have favorites.
New Update 2.5.1 on repository :
• Fix aspect ratio for widgets
• Minor fixes
• Update German translation
after update i cant click skins settings so how i can reset power ... menu ??
(2017-05-26, 23:45)badplay Wrote: [ -> ]after update i cant click skins settings so how i can reset power ... menu ??
Why you can't ? What's happen ?
Guilouz,
This skin is amazing!
Congrats for your daily work.
Are you planing to make any changes which need to reset menu and power settings again?
I have lots of custom widgets and playlist as menu items
btw, running v2.5.1 flawlessly
