Are there any future plans for VideoOSD additions/improvements? After playing around with other skins (Transparency! has a great example) I was just curious.
Thank you
(2017-06-23, 00:01)Guilouz Wrote: [ -> ] (2017-06-22, 22:53)fantasticn Wrote: [ -> ] (2017-06-22, 21:52)Guilouz Wrote: [ -> ]Can you detail actions you do to reproduce issue ? Because I just try with this settings enable and I can switch channels without problem.
Well, I just start a TV channel from the EPG and switch to fullscreen (which it actually does automatically). When I then try to change the channel up or down, I can hear the sound of the channel but I only see a rotating CD (Music visualisation). Interesting part is, when I press back (and thereby go back to the EPG screen) I have the video running in the mini window. When I then press back two times (first one takes me to the main screen, second takes me to fullscreen) video is running in fullscreen just fine again.
I have to mention that I am using Kodi on a Shield TV Box running TVheadend Client in combination with an external TVheadend Server running on LibreElec on a Wetek Play Box with two DVB-S tuners included. Maybe the client receives the audio signal slightly before the video signal and interprets it as being only audio. However, its strange that pressing back and returning to EPG will show the video running just fine in the mini window then.
Just try, working fine for me. Your issue is very strange, music visualisation is for music, not for PVR. Can you try last git, I have added a visibility condition for music fullscreen.
Yep, that solved the issue. Now it is working just fine. Thanks a lot!
(2017-06-23, 13:19)s0ulslack Wrote: [ -> ]Are there any future plans for VideoOSD additions/improvements? After playing around with other skins (Transparency! has a great example) I was just curious.
Thank you
What additions/improvements ?
I am encountering issues on initial startup where about 50%-75% of the time the widgets show a loading 'ring' instead of posters in moves, tv, etc.
I have not been able to recreate this issue using the standard estuary skin.
I suspect it may be a skin helper service interaction issue?
I am running :
ibreelec nightly #0623
EstuaryMod V2 2.5.9
skin helper service 1.1.17
Debug log:
http://paste.ubuntu.com/24937302/
Anything you would like me to test / try?
I've an external Blue Ray player attached to the computer. For some time now, 'Play disc' doesn't appear in the menu anymore. Couldn't say if this is a Leia problem or a skin problem. I'm on yesterday's nightly.
(2017-06-24, 04:08)wallacebw Wrote: [ -> ]I am encountering issues on initial startup where about 50%-75% of the time the widgets show a loading 'ring' instead of posters in moves, tv, etc.
I am running :
EstuaryMod V2 2.5.9
Debug log: http://paste.ubuntu.com/24937302/
I didn't see error for that in log. What widget have you define in settings ?
(2017-06-24, 14:21)Guilouz Wrote: [ -> ] (2017-06-24, 12:38)HeresJohnny Wrote: [ -> ]I've an external Blue Ray player attached to the computer. For some time now, 'Play disc' doesn't appear in the menu anymore. Couldn't say if this is a Leia problem or a skin problem. I'm on yesterday's nightly.
Working for me :
If I understand your screenshot, "play disc" should appear even with no blu-ray in it?
If yes, then it does not appear for me neither:
If no, I will have to try with a blu-ray inserted in my internal player
EDIT:
Find the answer myself: it shows up as soon as a Blu-Ray was inserted
Disc item appear when DVD/Blu-Ray is inserted in drive.
(2017-06-24, 13:09)Guilouz Wrote: [ -> ] (2017-06-24, 04:08)wallacebw Wrote: [ -> ]I am encountering issues on initial startup where about 50%-75% of the time the widgets show a loading 'ring' instead of posters in moves, tv, etc.
I am running :
EstuaryMod V2 2.5.9
I uploaded a skin settings backup, let me know if you need anything else.
https://www.sendspace.com/file/ckg2q6
(2017-06-26, 22:49)wallacebw Wrote: [ -> ] (2017-06-24, 13:09)Guilouz Wrote: [ -> ] (2017-06-24, 04:08)wallacebw Wrote: [ -> ]I am encountering issues on initial startup where about 50%-75% of the time the widgets show a loading 'ring' instead of posters in moves, tv, etc.
I am running :
EstuaryMod V2 2.5.9
Just say me what widgets you add in skin settings.
Can't seem to get CD art in my music library..i get album covers etc..but not CD art...can someone plewase help me..Thamls
On the Osd section when I play a movie I get nmo information...no logo,disc art e tcc
(2017-06-27, 05:16)Jay19802005 Wrote: [ -> ]Can't seem to get CD art in my music library..i get album covers etc..but not CD art...can someone plewase help me..Thamls
There is no CDart support in music library, only in movie library
