New Update 2.7.2 on repository :
• Add Top 250 from IMDb on dialog video info
• Add button to download all Artworks on dialog video info
• Add toggle button on PVR Guide to enable standard colors for genres
• Add setting to pause video during access to extended info
• Add possibility to configure media flags
• Change appearance of 'TV Show - Next Aired' addon
• Fix fanarts when 'Show video on background' is disable
• Minor changes
• Minor fixes
(2017-08-10, 23:29)Guilouz Wrote: [ -> ] (2017-08-10, 13:24)SharpCoder Wrote: [ -> ] (2017-08-10, 10:58)Angelinas Wrote: [ -> ]Are you use remote or keybord...or simular ¿
Maybe isue is from device not skin xml
I would assume that if "down" on the controller didn't work everywhere else in kodi but it does bar the custom widgets in question.
But to double check, i tried Kore on my phone, same result, tried my samsung tv remote via CEC, same result, and a spare Rii controller i had laying around, same result.
It's totally strange why it's not working, specifically for me and sure baffles me that's for sure.
EDIT: added video
https://www.youtube.com/watch?v=-JP5f-DIp7M
Very strange, impossible to me to reproduce this issue, I have tested with OSX and LibreELEC on my intel NUC and it's working. Nothing in log file ? Do you use latest Skin Shortcuts addon from Marcelveldt repo ?
here is kodi log
https://pastebin.com/2EjZpm2d
i have installed most addons needed by the skin in the nessecary section but librayeditor and marcelveldts repo dont work on it so i installed them from the following.
https://github.com/phil65/script.library...master.zip
https://github.com/marcelveldt/repositor...-1.0.1.zip
(2017-08-11, 02:21)SharpCoder Wrote: [ -> ] (2017-08-10, 23:29)Guilouz Wrote: [ -> ] (2017-08-10, 13:24)SharpCoder Wrote: [ -> ]I would assume that if "down" on the controller didn't work everywhere else in kodi but it does bar the custom widgets in question.
EDIT: added video
here is kodi log https://pastebin.com/2EjZpm2d
Please join a proper debug log, this one have multiple session with original estuary, estuary mod etc...
What I like to see in this screen when I hit Media info button, is the year and genre of the movie.
There is also a small bug where the movie aspect ration is not shown.
Is there an option to remove the white border from the banner?
(2017-08-12, 01:27)iMak Wrote: [ -> ]
Aspect ratio is correctly shown for me :
It's strange because it's correctly show on library. And I don't have movie with 5:3 aspect ratio to test.
I can do something like this :
Guys how put this menu:
Thanks for this update bro!!
(2017-08-12, 07:13)XxKaiserxX Wrote: [ -> ]Guys how put this menu:
In Skin settings / Home menu / Minimize main menu
Guilouz, can you bring back the "Big Poster" view in the V1 version? I don't know why it's removed in V2, and I tried to use other view types in V2, but not any view type in V2 can be a replacement for it. I use that view type very much.
Another issue, when I was moving focus from one item to another in the widget ("Recently added movies" widget, for example), I found the moving looks like a "jump" now, not that gentle as before, is this expected?
Got instant freeze on exit since a few days
Probably comes from one of the addon used by the skin
Nothing really usefull in the log
Do not freeze on fresh kodi install
