Hi guys i install the new version of kodi 17 and i cant find anywhere the sutitles.gr addon what i must do...?
I dont have much experience on Kodi i using it for 2 months only...
Hi, I tried installing it through the zip, but an error seems to pop up.
I unzipped it, and put it manually in the adddon folder, it is now showing up as a service subtitle but not working!
Any help would be much appreciated.
rename the dir from service.subtitles.substitles.gr/
to service.subtitles.subtitles.gr/
or re-download the zip from github and install it as before.
The subtitles.gr and subztv.gr add-ons require a dependency (script.module.lamlib) that no longer exists, as it was on lambda's github that was deleted.
So there is no possible way to get it working correct?
here it is:
https://github.com/ratmole/script.module.lamlib
do we know hat happened with lambda's account? was it taken down or has he/she delete the account by him self...?
also i want to know if there is a problem with the fork/clone.
Yes It Works!!!!! Thank you ratmole, you are the best!!!!!!!
From what I managed to see in twitter, lambda withdraws due to thieves!!!!
He said they were stealing his work.
You are the best men thank's...!!!!!!
It works!!!!! Thank you very much for the help... I appreciate
(2017-02-13, 15:41)ratmole Wrote: [ -> ]here it is:
Please can someone explain us how and what can we do to make it work as well .
We are not so familiar with the product so any help is much appreciated.
Thank you
(2017-08-23, 14:29)goshalim Wrote: [ -> ] (2017-02-13, 15:41)ratmole Wrote: [ -> ]here it is:
Thank you
step 1. You download the script.module.lamlib as a zip file from GitHub. You install it in your system from plugins/install from zip file
step 2. You download the subtitles as a zip file from GitHub.You install it as above.
this way the subtitles plugin finds the lamlib already installed in your system and it does not produce an error
Actually subtitles.gr add-on has been forked and updated, it's now in a repository that I don't think I should mention here.
Um... Why not?
Why not mention here the repository that is being currently updated, so that people can add it to their list of active repositories and keep having access to subtitles.gr subbtitle service?
That way we will not end up with a bunch of forks for the same addon, each containing different updates and/or bug fixes. The forked version that is being updated is already at version 1.2.5 (last lambda81 version was 1.2.1) and maybe people want to start contributing on that one.
