2017-02-13, 21:31
Is this even possible? I have set it up as per the Wiki instructions but I get an error from VLC (See Attach.)
The reason I am asking is only because VLC has the loop all feature and I need this when Internet traffic is heavy and I lose the stream temporarily. It's really bothersome to continue to hit Play for the channel over and over again and if I stream it in VLC it works fine. I really don't want to lose my channel setup or the awesome guide that kodi PVR has. If there would be a way to edit the PVR player and add a loop-all button that would solve everything.
NOTE: I have tried editing the guisettings.xml to repeat-all but I think this is only for video files and not PVR streams. It does not help the signal dropping out.
Thanks for any suggestions in advance.
Here is the VLC Log if it means anything to anyone...
lua debug: Trying Lua scripts in /home/steve/.local/share/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
core debug: no meta fetcher modules matched
core debug: searching art for pvr.iptvsimple_1284613416.pvr
core debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in /home/steve/.local/share/vlc/lua/meta/art
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
core debug: no art finder modules matched
core debug: looking for meta fetcher module matching "any": 1 candidates
core debug: using meta fetcher module "lua"
core debug: removing module "lua"
core debug: art not found for pvr.iptvsimple_1284613416.pvr
watch gallery
