2009-01-19, 09:52
2009-01-19, 17:43
germany does not have imdb links so you would be missing a lot of info. i do have a fix for the theaters not showing though.
2009-01-19, 18:15
Quote:i do have a fix for the theaters not showing thou
Thats great - if it is not to much trouble to fix. Looking forward to try it.
Please note that Amsterdam is located in the Netherlands and not Germany (but that does not make a difference I guess because indeed in both cases there are no imdb links).
Do you still want me to try Apple movie trailers II plugin tonight?
2009-01-19, 18:31
oh , there are a couple issues, so may be a day or two.
2009-01-19, 21:03
When I try to pull up the showtimes (using London as city) in the Apple movie trailers II plugin nothing happens. The movie trailers do play.
I am using xbmc on xbox build 8.10.
here is the log:
http://pastebin.com/m19faebd
Maybe a bad install on my side?
here is the log:
2009-01-20, 00:17
yor xbmc is too old.
2009-01-20, 02:57
Hi I have the same issue, when I put a location such as
it returns no result, but with AMT2 it does show..
2009-03-01, 20:26
I want to modify your plugin but i cant figure out how. Can you help me pls? Let me explain:
New plugin name: Theater Showtimes Lite
Source: Apple Movie Trailer II
I'm tyring popup just Fetch_Showtimes screen without Trailers.
I remove "xbmcplugin_download.py" and "xbmcplugin_trailers.py" then modify settings.xml
But i cant figure out how it should be default.py.
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<settings>
<setting id="local" type="text" label="30050" default="90210" />
<setting id="scraper" type="fileenum" mask="/" values="resources/scrapers/" label="30060" enable="!eq(-1,)" default="Google" />
<setting id="day" type="enum" lvalues="30071|30072|30073|30074|30075|30076|30077|30078" label="30070" enable="!eq(-2,)" default="0" />
</settings>
2009-03-07, 08:20
how can i link this plug-in up so i can view trailers from it? i cant seem to find the *.db file it needs....help please. works great otherwise...
thanks,
thanks,
2009-03-07, 17:43
this plugin only comes with the main amt script, so you should have your db.
2009-03-10, 20:54
Would you please re-upload the file and display the new link to your plugin. I'd like to add it to Navi-X, but can't because the file is missing or the link is broken. Thanks.
iRoNBiLL
iRoNBiLL
2009-03-11, 14:48
i mis spoke (wrong thread). this is a separate plugin in xbmc-addons.
to play trailers, if none are scraped from IMDb open plugin settings and browse for the AMT.db, which is created from Apple Movie Trailers script and set use AMT for trailers.
queeup, you need to create a default.py and pass the proper info. look at how it works in amt lite (ii)
2009-07-17, 22:39
hi, i installed 'theatre showtimes' from the 'svn repo' and when i select a theatre near me and then a movie - it shows showtimes , poster, cast, ... but the show trailer button on the bottom is greyed out.
how do i get the ability to see the movie trailer ?
_________________
i have tried checking 'refer to apple movie trailers' in the script settings.
also when i use the remote to select the location of AMT.db, xbmc automatically restarts.
_________________
2009-07-19, 00:15
also the cast is not being displayed
2009-12-01, 04:38
Is this plugin still working nuka? I just downloaded and configured it in Camelot Beta 1 and it's not giving me any listings at all
