2017-02-14, 19:01
Hello all.
Ok, this may sound like a noob question, and I admit my KODI / Android / Linux knowledge is very limited.
So, I have a 905x Android TV Box.
When I run LibreElec (from my microSD card) I can see that my TV Remote works fine on KODI, so I can use that for anything I want (navigation, etc). Trying to do a little research I found out that there is a lib / peripheral installed called "LibCec 3.0.1". My guess is that this lib is the reason my TV Remote works fine, and probably it is installed because LibreElec is actually running on Linux (right ? ).
Now, when I boot on Android (my Tv Box), my TV Remote does not work on KODI and / or SPMC.
Navigating to the settings / Inputs / Peripherals menu, I confirmed that in this case (Android) there is no such lib as "LibCec" or anything related to support the TV Remote.
So, is there any other / alternative way I can enable the use of my TV Remote for the basic functions of KODI when it runs on Android ?
Thank you in advance.
