Hey,
i saw that there is a db-viewer version for Kodi 18 with implemented format settings. here you can choose for example WebM oer TS. Additional to that you can set additional parameter.
Is it possible to implement that options to Kodi 17 dvb-viewer or a way to export the pvr and import it?
I can´t switch to Kodi 18, because other important pvr-clients i use, are not compatible.
Thank you!
Kodi 17 backports exist, see
here. You need to compile it yourself though.
(2017-02-17, 12:16)CiNcH Wrote: [ -> ]Kodi 17 backports exist, see here. You need to compile it yourself though.
Thank you for your reply. Unfortunately i have no idea about compiling
Can you or someone else help me?
(2017-02-17, 14:48)manül Wrote: [ -> ]Which OS/platform?
Hi manül,
OS is LibreELEC v.7.95.3 (Kodi 17.0) on Generic X86_64.
greets
I'll provide you with a build later or tomorrow.
(2017-02-17, 18:40)manül Wrote: [ -> ]I'll provide you with a build later or tomorrow.
That ist nice, thank you very much!
Thanks for that. Saved my day. BTW the build is not included in 17.1 for Ubuntu
(2017-02-17, 09:43)Modjo Wrote: [ -> ]Hey,
Thank you!
I found this nice feature in the most recent DVBviewer plug-in. Using transcodinge (either WebM, TS, FLV) is clear to me - but what is meant with transcoding URL parameters ? Just a number for max. MBit ?
