Kodi has been running on this hardware for years without issue, but recently, it is unable to start. I created a clean ~/.kodi to minimize variables. Debug is
here. Any thoughts are welcomed.
wrong gpu drivers or no xserver available. It's not a
Debug Log - so I cannot see.
As it worked for years -> check what you "ARCHgraded" ...
glxinfo is needed - your log does not startup with debugging therefore I cannot even say which GPU driver / userspace side you are using.
Your issue has nothing to do with kodi. But driver / userspace f*ckup :-)
fritsch - Is there anything else I can place in advancedsettings.xml to help? Currently, starting it with:
# cat /var/lib/kodi/.kodi/userdata/advancedsettings.xml
<advancedsettings>
<loglevel>1</loglevel>
<debug>
<extralogging>true</extralogging>
<setextraloglevel>32,64,128,256,512,1024,2048,4096,8192,16384,32768,65536</setextraloglevel>
<showloginfo>true</showloginfo>
</debug>
</advancedsettings>
More info:
The segfault and errors only happen when I try launch using the
kodi user/systemd service.
If I log in to lxdm as another user, and launch kodi from a shell, it runs as expected.
Debug log after manually logging into lxdm and launching from another user:
here.
EDIT: I think the problem is with xorg-server... downgrading it (and others) returns functionality.
Packages (22) alsa-utils-1.1.3-2 bash-4.4.012-1 bzip2-1.0.6-6 dbus-1.10.16-1 fixesproto-5.0+9+g4292ec1-1 glib2-2.50.3-1
gnutls-3.5.9-1 guile-2.0.14-1 libkscreen-5.9.2-1 libnl-3.2.29-2 linux-4.9.9-1 mesa-17.0.0-1
ncurses-6.0+20170128-1 nvidia-340xx-340.102-1 nvidia-340xx-libgl-340.102-1 nvidia-340xx-utils-340.102-1
readline-7.0.003-1 sqlite-3.17.0-1 vim-8.0.0329-1 vim-runtime-8.0.0329-1 xorg-server-1.19.1-5
xorg-server-common-1.19.1-5
I don't have time to debug further now, but the problem is likely due to one of the above + the systemd standalone-service on this particular hardware. Note for others following this thread that the packages listed above are from 14-Feb-2017 snapshot.
not in the x-server business. updated to the latest kodi version from git, the same error
Guys - if no Xserver is available kodi cannot start. This has nothing to do with kodi ... if you start xterm you will get the very same error.
the Xserver starts up normally. Kodi does not work.
kodi from last version git falls with error.
rolled back to the old version Kodi (18-Alpha1, git:20170819-0f9abae) and it all worked again.
See this exactly happens when people shout "me too". without a
Debug Log. I fixed a problem for GLX (run on nvidia gpus) yesterday, which might have fixed your personal issue which has absolutely nothing to do with the OP's issue.
Since your fix, I'm having the "Failed to find matching visual" errror. This is the log of Milhouse Generic LibreELEC.tv Leia build #0921:
https://pastebin.com/hLLYB0u2
Same problem here NVidia card and after kodi updates same segfault, got a new update 5 minutes ago and same:
22:08:55.199 T:140291348166976 INFO: Pixel Ratio: 1.333618
22:08:55.199 T:140291348166976 NOTICE: Checking resolution 15
22:08:55.199 T:140291348166976 ERROR: Failed to find matching visual
22:08:55.199 T:140291348166976 INFO: GL: Maximum texture width: 32768
(2017-09-22, 06:44)MaxMustermann Wrote: [ -> ]Since your fix, I'm having the "Failed to find matching visual" errror. This is the log of Milhouse Generic LibreELEC.tv Leia build #0921: https://pastebin.com/hLLYB0u2
So then, please use the build before that which does not have this PR:
http://milhouse.libreelec.tv/builds/mast...98a31e.tar (#0918) - working?
Edit: Yeah, it will work, cause the root cause is: [X11] factor out glx support (PR:12219, 4 commits, 11 files changed) which I tried to fix - so no chance for you to test that. So then, stay on 0918 for now
For the selfbuilders:
Revert my fix, revert: [X11] factor out glx support (PR:12219, 4 commits, 11 files changed) and it should be back to normal.
If my build is crashing, can someone post a crashlog?
