(2019-02-12, 07:44)antgash Wrote: [ -> ]Hi Alanon, I love this skin, and i'm just wondering if there are still updates planned in the near future? there's a few issues with the Leia skin that's causing me to fall back on other skins. Namely, the lack of a scrollbar, the viewed icon being forced on EVERY movie including unviewed (blank grey circle), and the in progress movies section not working. I'm on 3.0.4
Sorry if these are all known issues already, there's a lot of pages to comb through.
Hello, sorry for the late response, I've been having ISP troubles. In a nutshell, yes, the skin is still maintained, updates are planned, but I can't give any reliable ETAs since my free time has taken a hit in the past few months. Currently, I'm working on some remaining Leia features like the new game interface. There are some bugs on my checklist that I hope I'll have the skill to squash, but, as I've said, it's all dependent on my free time and the severity/persistence of the issues.
Now, on to the things you've mentioned. The scrollbars are there, activated by a skin setting? (Skin Settings/Library options/Use regular scrollbars) There's a classic scrollbar and an alphabet scrollbar that allows for direct letter-by-letter content skipping. You can activate one, both, or neither. I've had no complaints since instituting the feature, so to the best of my knowledge, everything should work.
As far as the indicators go, again, I'm not quite sure what you mean. There is an indicator setting in the library submenu with three options:
All (which shows all indicators),
Hide watched (which hides the green checkmarks) and
Hide unwatched (which hides the blank circles). That ought to provide sufficient flexibility. I've tested them out now and they work as intended.
Finally, in progress movies, as in the widget? Is that what you were referring to? If it is, then it's all tied to skin helper widgets and various APIs it uses, I've tested it out and it works correctly for me. If you were referring to something else, I'll needsomee more info.
