(2017-03-14, 23:34)eurogroovem5 Wrote: [ -> ]Alanon,
Good day. Had a few issues arise and felt that I had to bring them to your attention. I appreciate the work and effort you put into hearing our issues.
-I am hiding submenu icons. When I click reload skin on the power submenu, the skin reloads but ignores the hide submenu icons toggle and alas, i see the icons. I retry the toggle and cant get the icons to disappear.
-I am trying to have Library as a submenu item. ActivateWindow(LibrarySettings) Does not work for me. Anyone else?
A few ideas I want to throw out there...
-RSS on Text Only home bar. Perhaps an option for above or below the home bar as well.
-Replace widget fanart with background on a per hub basis instead of all or none.
I have a wallpaper heavy build. I wanted to lighten the build size by removing a percentage of wallpapers and just use the widget fanart as backgrounds on some of the hubs. Turns out that some widgets just give me a white background.
-Hub images have the ability to link to a certain add-on folder. i understand that I can just set it using the hub widget. I just find that hub images load instantaneously and some hub widgets take a few minutes.
1. I've never had that happen. I've tried toying with it now, and can't reproduce it. The only thing that comes to mind is that something went wrong in saving the skin settings. You might try re-toggling the submenu type first, and then the icons? Sometimes these things get borked, probably due to Skin Helper sensitivity. Alternatively, you might try delving into the userdata settings.xml file manually, to try and see if the proper setting is present? As a last resort, move that file somewhere else, so that you might try resetting all the skin settings to see if it will work out of the box.
2. As far as I know, there's no such window. If you're trying to access the library settings themselves (where the library source buttons - Videos... Music... Pictures... are located), then use ActivateWindow(mediasettings). Otherwise, you'll have to use windows by category (videos, etc...).
3. Hm... I don't use RSS, so I wasn't aware it was disabled in text only. I'll look into it.
4. What do you mean by hub images? The entries next to the widget? The shortcuts can add anything that the main menu or sub menu shortcuts can, including add-on folders. The add-on itself, however, must allow for such external browsing. Either way, as far as hub functionality is concerned, my hands are pretty much tied, since everything is handled by the script.skinshortcuts add-on.
(2017-03-14, 23:56)odelot Wrote: [ -> ]Hello again Alanon, I have tried Adding Source inside "Coleccion" in Kodi, (I think that this is the file manager):
With a example image, but this source not appear when I click on "Background", only appears this:
And selecting "Imagen unica" appears this:
And I can't select nothing more to navigate up of "Catoal", only inside of this, but without any folder of Android.
No, this is not it. The place you went to controls media sources. The file manager is a separate window. In both Eminence skins it can only be accessed through adding a menu or a submenu shortcut.
In the default Estuary skin, there is a File Manager shortcut in the main settings screen, you can use that if it's easier?
Once you access the file manager, then you add a source, and then it will be displayed in the image selection window.
