(2019-02-02, 00:25)spinnaker Wrote: [ -> ]I tried following the instructions in posts 1 and 2. When I look at my dependencies, it says I am missing script.module.simpleeval.
I am not seeing it in any of the downloads above. Where do I get this file?
Found it
https://forum.kodi.tv/showthread.php?tid...pid2808714
Thank you SO much! I have my Eminence back!
I can't seem to get Customize Home Menu to work. I see no errors. Selecting Customize Home Menu just doesn't do anything.
Ditto for Quick Nav and Shutdown Menu.
I am using the Windows 10 Version of Kodi, Latest Build.
P.S. I am now seeing the same behavior in Pellucid. I know that used to work. Not sure what would have broken it. The install of the Eminence Mod or one of the dependencies maybe?
Is there any way to change the style of the view that lists all of the TV Shows? I see how to change the style of the individual shows but what I am refereing to is the list of all of the shows. I am not crazy about rolodex styles. Can't see how to change it.
Post #2 says
5. For the Weather widget to work, you must install the multi fanart artwork. For the moment it is needed for the widget to appear.
So where can multi fanart be found? I am not seeing it listed in post #1
I see a setting for this uder resourse. Is that it? If so soes not seem to do anything.
BTW the (degrees) F shows up on the screen. Just not the temp.
Edit I was able to get Weather to work. I go onto the Addon and selected Use.
The HD HomeRun AddOn is not working in Eminence.
A green vertical bar is shown on the left, a spinning clock in the lower left, the HD logo remains right in the center. You can't select channels. Other skins it works fine.
spinnaker Unless they are listed in the first post, all the add-ons can be downloaded from the official Kodi repo. Weather multifanart can be downloaded from the official Kodi repo that is included with Kodi, just search for the add-on from within the program and you should be able to install it easily. For minimum functionality, you need to install marcelveldt's beta repo for skin dependencies like skin shortcuts. To resolve your menu issues, you need to make sure you are using Marcel's versions because they are different from the official ones. The skin still uses those beta versions, and everything works with them. If you have Marcel's repo installed, just re-install skinshortcuts from his repo - not the official one - and it should begin working.
I'm not sure what you mean about TV Show views? When you are in the root of your TV show library, pressing
m on the keyboard should display a menu, and the first entry should lead you to a selector for available view types. Unless you have manually hidden various views, you should see all available view types with screenshots. There are currently 39 views available specifically for tv shows (not episodes). The skin separates episodes from tv shows automatically and memorises the selected view types separately unless you are using some third party add-on that modifies skin behaviour.
Finally, I have no idea about that add-on. Is it some sort of PVR Live TV backend? I will need some debug logs to troubleshoot this behaviour.
Got it on the TV Shows. Thanks.
Only two issues remain are not being able to edit menus and the HD Home Run plugin issue.
What do you want me to do to collect logs?
In the process of preparing log files now.
Here is the log when running HDHomeRun from Eminence
https://paste.kodi.tv/ejudikonog.kodi
Here is the log when running from Estuary (which works)
https://paste.kodi.tv/apamidozis.kodi
One thing I noticed, In Estuary the busy symbol is a small rotating clock right in the center of the screen. In Eminence, it is a much larger clock in the lower right. There is a box underneath. I will try and upload screen shots in a bit.
Here is the busy icon in Eminence
Here is the busy icon in Estuary.
(2019-02-02, 05:04)spinnaker Wrote: [ -> ]Here is the log when trying to configure the menu in skin settings
https://paste.kodi.tv/kobuyoxive.kodi
I noticed several errors.
Here is an interesting one
ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\Stefan\AppData\Roaming\Kodi\Theme\movies\
I am not Stefan! No idea where that came from
ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/?info=incinemas
2:00:44.175 T:4824 ERROR: CScriptInvocationManager::ExecuteAsync - Not executing non-existing script script.skinshortcuts
that one seems to be a theme. It took a couple of tries but it finally instilled. I noticed two versions. One from Kodi repository and one from Marcel. I installed the Kodi one and it seemed to fix the menu issue. My whole menu looked different when I started Kodi. I had a lot more options.
The HDHome Run issue remains. I will upload a fresh log.
Updated log after starting HDHomeRun
https://paste.kodi.tv/eziyuyizek.kodi
I don't think you need HDHomeRun to load the plugin. When starting it will simply say it can't find devices.
I noticed these
ERROR: ffmpeg[2E8]: [mpeg2video] Invalid frame dimensions 0x0. 04:30:10.883 T:744 ERROR: Previous line repeats 7 times.
This one might be relevant. I fact it appears to be the only error now. The Stefan directory error is gone.
There is an HDHomeRun Simple that works but unfortunately the guide does not seem to work. Plus it is not as nearly as nice as the regular plugin
Alanon Any chance you could look into what I would need to do to get Global Search up and working on the skin on Kodi Leia?
version 6.06 will work, but if you play a movie it often crashes Kodi to desktop.
the newer, more updated versions written for Leia do not work at all and return no search.
Alanon keep in mind this DID work on the skin at some point (i'm thinking Krypton?) but no longer does.
