2017-02-20, 23:45
Hello, since I upgraded to Krypton I'm facing this issue:
Each time I boot Kodi the font isn't loaded somewhere around the skin.
I've checked of course before that it wasn't a skin related issue, and this is what the skin's coder said (Titan skin)
I'm running Kodi v17 stable under Win10 x64.
The steps to reproduce the issue are:
- Having at least 2 users
- Using a different skin than default ones (probably a skin with multiple font support, I.E. Titan)
- Log in with a user, you should face the issue.
A workaround until next reboot/log off is changing skin or selecting again the font into appearance settings.
Please fix this as it's very annoying for people using multiple users.
Thank you in advance
(2017-02-20, 01:52)marcelveldt Wrote: [ -> ]Seems to be a kodi bug indeed, I could easily reproduce it.
The issue is that the default font setting isn't set for the additional users, leaving the skín's font empty.
For your additional user(s), just go to settings --> appearance and set the font once to correct the issue.
Can I also ask you to report this issue to the Kodi team ?
