I searched the forum thinking there would be a way to increase the value of the shutdown timer beyond 120, either I missed it or it's not there.
Just to be clear what I want to change, Settings - System - Power Savings - Shutdown function timer
The timer has a maximum value if 120 minutes, I would like to increase it to 480 minutes.
Can someone point me in the right direction?
/usr/share/kodi/system/settings/settings.xml:
<setting id="powermanagement.shutdowntime" type="integer" label="357" help="36389">
<level>2</level>
<default>0</default>
<constraints>
<minimum label="351">0</minimum>
<step>5</step>
<maximum>120</maximum>
</constraints>
<control type="spinner" format="string">
<formatlabel>14044</formatlabel>
</control>
</setting>
Do not edit the file directly, better copy the this (including its category tag) to advancedsettings.xml
Thanks wsnipex, that works.
I cannot figure this out for the life of me. I've tried all variations of this in advancedsettings (with/without <category>/<group>/<settings>). I'm on Libreelec 8.2.5. Advancedsettings is working well otherwise as MySQL is working.
<category id="powermanagement" label="14095" help="36387">
<group id="1" label="14255">
<level>2</level>
<constraints>
<step>5</step>
<maximum>300</maximum>
</constraints>
</control>
</setting>
</group>
</category>
