2008-01-22, 07:10
Basics-Vision
I had some spare time over the school holidays and started mucking around making a Basics-101 / VISION hybrid skin ( like they had sex and made a bastard child ) Pretty much its basics-101 redesigned into a vision look but more how I thought it should be.
The skin is now finished and ready for download. I call it "Basic-Vision" because I'm uncreative when it comes to names
Oh one side effect for people is since its a remake of basics-101 its really going to be 720p only with basic 16x9 support unlike Vision that supported 4x3 as well Hopefully I can get 4x3 support in but its not looking like its going to be easy
Make sure you check out the skin settings (Go left in settings) and check out how different it looks with "Use Alternate Home Layout" and "Use Full Icon Size" turned on
DOWNLOAD LINK (updated 1st FEb 2008 .au time)
Ok here is the new 'Latest" version as of now for those who choose not to use the SVN
Included in this one is complete 4x3 support
Basics-Vision_Revision_1142.rar
Complete changelog since first added to the SVN
SVN URL <--- updated lots more than the download will ever be
Screenshots
http://i13.photobucket.com/albums/a273/J...hot066.jpg
http://i13.photobucket.com/albums/a273/J...hot065.jpg
http://i13.photobucket.com/albums/a273/J...hot064.jpg
http://i13.photobucket.com/albums/a273/J...hot063.jpg
http://i13.photobucket.com/albums/a273/J...hot062.jpg
http://i13.photobucket.com/albums/a273/J...hot008.jpg
http://i13.photobucket.com/albums/a273/J...hot058.jpg
http://i13.photobucket.com/albums/a273/J...hot002.jpg
http://i13.photobucket.com/albums/a273/J...hot054.jpg
http://i13.photobucket.com/albums/a273/J...hot055.jpg
http://i13.photobucket.com/albums/a273/J...hot056.jpg
http://i13.photobucket.com/albums/a273/J...hot057.jpg
http://i13.photobucket.com/albums/a273/J...hot050.jpg
http://i13.photobucket.com/albums/a273/J...hot051.jpg
http://i13.photobucket.com/albums/a273/J...hot052.jpg
http://i13.photobucket.com/albums/a273/J...hot053.jpg
http://i13.photobucket.com/albums/a273/J...hot049.jpg
http://i13.photobucket.com/albums/a273/J...hot048.jpg
http://i13.photobucket.com/albums/a273/J...hot044.jpg
http://i13.photobucket.com/albums/a273/J...hot040.jpg
http://i13.photobucket.com/albums/a273/J...hot038.jpg
http://i13.photobucket.com/albums/a273/J...hot034.jpg
http://i13.photobucket.com/albums/a273/J...hot035.jpg
http://i13.photobucket.com/albums/a273/J...hot033.jpg
http://i13.photobucket.com/albums/a273/J...hot032.jpg
http://i13.photobucket.com/albums/a273/J...hot031.jpg
http://i13.photobucket.com/albums/a273/J...hot030.jpg
http://i13.photobucket.com/albums/a273/J...hot029.jpg
http://i13.photobucket.com/albums/a273/J...hot028.jpg
http://i13.photobucket.com/albums/a273/J...hot027.jpg
http://i13.photobucket.com/albums/a273/J...hot026.jpg
http://i13.photobucket.com/albums/a273/J...hot025.jpg
http://i13.photobucket.com/albums/a273/J...hot024.jpg
http://i13.photobucket.com/albums/a273/J...hot023.jpg
http://i13.photobucket.com/albums/a273/J...hot022.jpg
http://i13.photobucket.com/albums/a273/J...hot021.jpg
http://i13.photobucket.com/albums/a273/J...hot020.jpg
http://i13.photobucket.com/albums/a273/J...hot019.jpg
http://i13.photobucket.com/albums/a273/J...hot018.jpg
http://i13.photobucket.com/albums/a273/J...hot016.jpg
http://i13.photobucket.com/albums/a273/J...hot015.jpg
Quote:Date Rev Message
2008-01-31 1142 Added : Play trailer button to DialogVideoInfo.xml
2008-01-31 1141 Added : Possible fix for music and video scanning dialogs never reappearing from going to full screen video music windows
2008-01-30 1140 Changed : Coverflow view now added to video files and library for PAL 4x3 that makes the last of the 4x3 stuff finished
2008-01-30 1132 CHanged : Now Playing title now scrolls in home if it is too long Changed : Now Playing in sub pages uses a smaller font and higher up so it doesn't go over window title text
2008-01-30 1131 Fixed : 16x9 resolutions couldn't reset custom wallpaper
2008-01-30 1130 Added : 4x3 Music Coverflow Video coming soon
2008-01-29 1119 Fixed : (hopefully) Clock in home circle getting cut off Added : Option to skin settings to choose a custom background for the whole skin
2008-01-29 1118 Added : Skin Setting to move the time from the top to the middle of the circle in the traditional home screen
2008-01-29 1117 Added : "Big List" view type to all media windows. This is just list view with no big icon so full screen width
2008-01-29 1116 Changed : Finished off making AMT look better in 4x3 (except for coverflow that is 4x3 pretty much done) yippe
2008-01-29 1115 Changed : Lyrics script skin for 4x3 tidied up Changed : a few small 4x3 tweeks
2008-01-28 1114 Finished : 4x3ing the music and video library "Media Info" Views
2008-01-28 1113 Changed : couple more 4x3 files done
2008-01-28 1111 Fixed : some Nav issues in music and video OSD Added : 4x3 PAL stuff to the build.bat stuff Skinned : some more 4x3 stuff (still more to go mainly scripts and media info views)
2008-01-28 1110 Uploaded : the 4x3 files for the skin so I don't loose them not all are done yet (about 70% are) and 4x3 dosn't have coverflow in it (yet)
2008-01-24 1108 Changed the coverflow animation timing a little
2008-01-23 1106 Fixed : Skin has invalid include: Slide_From_Right_Animation
2008-01-23 1105 Added : BUILD_SKIN_If_Other_Dosn't_Work.bat for people having problems with the old BUILD_SKIN.bat
2008-01-23 1104 Changed : Going up on both menus now opens Favourites Dialog . Going down on ALt home opens shutdown dialog, (not sure if its staying a see accidental clicks happening)
2008-01-23 1103 Changed : Made Page control Nav up got to current media view (better for coverflow) Changed : Coverflow views loose blue border when not selected (eg: on page controls)
2008-01-23 1102 Changed : Code cleanup
2008-01-23 1101 Added : Coverflow view to music
2008-01-23 1100 Added : Work around for background_diffuse.png texture flashing on entering alt home on linux version of xbmc (new already transparent home texture called background_2.png) Added : Coverflow view to the Video sections (really only for dvd posters because other aspects will just get stretched out to fit)
2008-01-22 1099 Inital Commit of the Basics-Vision skin thanks to Mikebeecham for the Icons use againThis skin is really only meant for 720p but should work on any 16x9 resolution 4x3 is not good The skin also required a fairly recent build of XBMC (no more than a week old)to function proper
https://xboxmediacenter.svn.sourceforge.net/svnroot/xboxmediacenter/Basics-Vision
Screenshots
