(2017-03-06, 22:26)Memphiz Wrote: [ -> ]Open the console app in utilities and navigate to ~/Library/Logs - there should be the kodi.log in there
Hi thanks for that Memphiz
Here is the link to my log --
http://pastebin.com/jzTyNxRX
Cheers
I'm new to this and have the same issues. How to I access my log? Then access the debug log when everything keeps crashing?
I think this is the correct log of my crash
http://pastebin.com/ChcfMdVX
Hawk1989 please provide your addons27.db to me (dropbox?) then delete it - that should make it work again. (I need that file to analyse the corruption it has.).
dtran555 kodi 17 needs osx 10.8 at least
(2017-03-07, 08:40)Memphiz Wrote: [ -> ]@Hawk1989 please provide your addons27.db to me (dropbox?) then delete it - that should make it work again. (I need that file to analyse the corruption it has.).
@dtran555 kodi 17 needs osx 10.8 at least
Hi there
found the addons27.db removed from database folder
Tried starting Kodi - same issue again
then.....deleted kodi, turned computer off and on again, reinstalled .... same .... arrrgh!
looks like kodi rebuilt addons27.db though as its back, same file size
Hawk, new log file please !!!!
Delete addons26 db too (or any lower version)
hello,
I am having a similar issue as mentioned above. Kodi is stalling at the initial start up page and freezing causing me to force quit with out it loading.
Here's my log.
http://pastebin.com/68n0BiQi
Thanks in advance.
(2017-03-07, 19:06)Memphiz Wrote: [ -> ]Delete addons26 db too (or any lower version)
Thanks for all you help Memphiz
You've solved my issue. Im back!!!!
I was deleting addon27.db and was still having same issue but when Ive deleted any lower versions (addons20.db) as well I'm back on
You're a legend
Cheers mate
(2017-03-07, 23:15)mattc9 Wrote: [ -> ]hello,
Here's my log.
Thanks in advance.
53:39.621 T:123145531707392 ERtROR: SQL: [Textures13.db] SQL error or missing database
And you also have a corrupt database, please delete Textures13.db it so kodi can rebuild it.
You can find Textures13.db in your userdata (wiki) (databases) folder.
I am new to this coding stuff, so I have no clue what deleting a log means. I had Jarvis and tried to download Kodi 17 and it keeps failing to open, saying there was an unexpected error. I am currently running MacOS Seirra 10.12.3, please help!!!
(2017-03-09, 06:57)car07d Wrote: [ -> ]I am new to this coding stuff, so I have no clue what deleting a log means. I had Jarvis and tried to download Kodi 17 and it keeps failing to open, saying there was an unexpected error. I am currently running MacOS Seirra 10.12.3, please help!!!
You have to read a little and know some more to get some help. We need a
debug log so we can try to see what is going wrong.
I had Kodi on my computer and it was booting me out saying that is stopped working and that i would not be able to open it back up. I deleted it completely off my computer and tried to re-download it but now it will not even open. Keeps saying Kodi stopped working and will not open.
Im not a computer person and tried reading these blogs but could not figure it out. Can anyone explain what is going on or how to fix it in basic terms?
(2017-03-10, 08:40)xexvex Wrote: [ -> ]Hi guys same thing happened to me. I'm on El Captain 10.11.6
Here is my Log: http://pastebin.com/Df7hZAPt
We really need a
debug log. You can get it
manually from the OSX folder if kodi is not able to produce one.
