2021-02-16, 01:29
With „clean thumbnails“ it deletes all tumbnails but automatically recreates them while navigating through my library, without any additional scanning, etc?
(2021-02-16, 01:29)pigeldi Wrote: [ -> ]With „clean thumbnails“ it deletes all tumbnails but automatically recreates them while navigating through my library, without any additional scanning, etc?
(2021-02-09, 21:14)kristofferR Wrote: [ -> ]Eh, you guys are aware that he released a Matrix version, right?
http://kodi.lanik.org/_p3repo/script.kcl...r-4.02.zip
Repo:
http://kodi.lanik.org/_repo/lanik.repo/l...-1.0.2.zip
(2021-02-23, 01:25)MAX404 Wrote: [ -> ]Thank you Mr. Lanik !!!
(2021-05-23, 00:53)MAX404 Wrote: [ -> ]I was trying this on Kodi 20 , works OK on Kodi 19.(2021-05-22, 22:02)rocko Wrote: [ -> ](2021-03-12, 00:40)RB26 Wrote: [ -> ]I second this. Worked great!
Worked for me on Kodi Matrix on my streaming box but trying to load now on computer and links are dead.
Any ideas
hi
try here
(2021-05-23, 17:51)rocko Wrote: [ -> ](2021-05-23, 00:53)MAX404 Wrote: [ -> ]I was trying this on Kodi 20 , works OK on Kodi 19.(2021-05-22, 22:02)rocko Wrote: [ -> ]Worked for me on Kodi Matrix on my streaming box but trying to load now on computer and links are dead.
Any ideas
hi
try here
Installed OK but won't open. Several other addons don't work either so I went back to Kodi 19 for now.
(2021-05-24, 01:02)MAX404 Wrote: [ -> ]I forgot to say I was trying K cleaner on Kodi 20.(2021-05-23, 17:51)rocko Wrote: [ -> ](2021-05-23, 00:53)MAX404 Wrote: [ -> ]hiI was trying this on Kodi 20 , works OK on Kodi 19.
try here
Hi
I do not think they are updated to Kodi 20 yet, he never said they were
Quote:9:38:09.224 T:13716 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'TypeError'>
Error Contents: can only concatenate str (not "bytes") to str
File "C:\Users\home\AppData\Roaming\Kodi\addons\script.kcleaner\default.py", line 1262, in getPathAddons
xmldoc = minidom.parseString(httpdata)
File "C:\Program Files (x86)\Kodi\system\python\Lib\xml\dom\minidom.py", line 1969, in parseString
return expatbuilder.parseString(string)
File "C:\Program Files (x86)\Kodi\system\python\Lib\xml\dom\expatbuilder.py", line 925, in parseString
return builder.parseString(string)
File "C:\Program Files (x86)\Kodi\system\python\Lib\xml\dom\expatbuilder.py", line 223, in parseString
parser.Parse(string, True)
xml.parsers.expat.ExpatError: not well-formed (invalid token): line 186, column 79
During handling of the above exception, another exception occurred:
File "C:\Users\home\AppData\Roaming\Kodi\addons\script.kcleaner\default.py", line 1963, in <module>
intCancel = ProcessAddons(0)
File "C:\Users\home\AppData\Roaming\Kodi\addons\script.kcleaner\default.py", line 1053, in ProcessAddons
AddonsInRepo += GetAddonsInRepo(repoxml, r)
File "C:\Users\home\AppData\Roaming\Kodi\addons\script.kcleaner\default.py", line 1190, in GetAddonsInRepo
id = getPathAddons(ri, repo)
File "C:\Users\home\AppData\Roaming\Kodi\addons\script.kcleaner\default.py", line 1264, in getPathAddons
xbmc.log("KCLEANER >> ERROR PARSING REPO >> " + str(e).encode('utf-8'))
TypeError: can only concatenate str (not "bytes") to str
(2021-06-12, 00:16)tstrul Wrote: [ -> ]Hey,
Thank you for updating this addon for kodi 19.
I still have one problem though, when trying to find addons without repository/find repos without installed addons im getting an error.
