Skins Support
Amber
> Can't disable QUIT in main menu
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Merwenus
2017-02-24, 15:48
Setting says
DISABLED
But it is still in the main menu.
What did I mess up? Fresh install of Krypton 17, do I have to disable it somewhere else too?
joethepartylion
2017-02-24, 16:51
Hi, thanks for the report
It should be fixed here
https://github.com/joethepartylion/skin....fe0a2cd2e9
Merwenus
2017-02-24, 19:42
Thank you it works now.
Skins Support
Amber
