Full Version: I fail to install pvr.vnsi.vdr...
I get kodi (17.1 compiled and installed using cmake.
i get vpr.vnsi.vdr compiled with cmake - but how to install - i don't end up with so's in /usr/local/lib - nor elsewhere
last lines of the log of make are:
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/resources/language/resource.language.nl_nl/strings.po
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/resources/language/resource.language.uk_ua
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/resources/language/resource.language.uk_ua/strings.po
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/resources/settings.xml
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/addon.xml
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/.//pvr.vdr.vnsi/addon.xml.in
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.so.2.6.19
-- Up-to-date: /usr/local/src/Krypton/xbmc/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.so.17.1
[ 84%] Completed 'pvr.vdr.vnsi'
[100%] Built target pvr.vdr.vnsi
In case you issued the correct cmake command, the last command is: make sudo-install
The cmake was :
cmake -DADDONS_TO_BUILD=pvr.vdr.vnsi -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=../../xbmc/addons -DPACKAGE_ZIP=1 ../../xbmc/project/cmake/addons
make sudo-install gives : "No rule ...."
kodi's installer does not install addons that were copied into its build directory anymore. as a result you have to set CMAKE_INSTALL_PREFIX to final
cmake -DADDONS_TO_BUILD=pvr.vdr.vnsi -DCMAKE_INSTALL_PREFIX=/usr/local -DADDON_SRC_PREFIX=/home/xbmc/progs/src /home/xbmc/progs/src/xbmc/project/cmake/addons
