(2017-03-17, 16:38)mxlance Wrote: [ -> ]I really like what you are doing with (fuse)neue
I especially like the consistent design through out.
My question is, why use widgets and a home screen in (fuse)neue? Could you instead bypass the traditional home menu/screen. Just use the View screen/s as the home menu screen.
I just pushed an update to use the startupwindow setting.
"Settings > Interface > Other > Startup Window."
So combined with the press back to open the top bar option, this means you never have to go home
"Skin Settings > Home > Allow pressing back to open the top bar"
I'm a little concerned that entirely removing the home screen might cause a bunch of issues for certain use cases (I'm not sure what, but I'm sure there is something!).
Plus, now that I've implemented submenu widgets I've actually gone the other way with my setup on my htpc in the loungeroom. Instead I have a different widget for every home item so that you don't really even need to leave the home page (e.g. under movies I have a submenu item recently added and a widget that shows recently added, another that is recently played and then a widget that points to that playlist and so on). I'm finding this even more effective as the content is always readily available.
This way you have three different setup options:
1. The traditional way of a home screen and library sections.
2. A setup where pretty much everything is available from the home screen and the transition into the library occurs seamlessly.
3. A setup where you are always in the library and never really ever go home.
The basic idea is to get to your content with as few clicks as possible and have the transitions between different areas occur seamlessly so you aren't really thinking about where you are, you are just thinking about what content you want to watch/listen to. I can appreciate that there might be different preferences about what feels more natural to do this so "Por que no los dos?"
(2017-03-17, 23:43)realjohngalt Wrote: [ -> ]Edit: A potential bug: The color 4k mediaflag says "Altra" and not "Ultra" https://i.imgur.com/PxSzKBa.png and https://github.com/jurialmunkey/skin.fus...ion/4K.png
Yeah I noticed that. I didn't make the flags, I just used the ones from the resource file that Edworld supplied. I've sourced some other colour flags now so it just says HD 2160p -- though this isn't exactly ideal either as it should say 4K not HD so I'm thinking I might have to make my own (at least now it doesn't say altra though!)
(2017-03-18, 02:41)Blurayx Wrote: [ -> ]Hi jurialmunkey,
Nice skin, It's slowly growing on me
synology NAS:
After entering user name the password option takes a long time to appear or sometimes doesn't show at all.
Are you sure this only happens in this skin? I don't use a NAS so I can't really test, though I can't imagine what in particular would cause this behaviour in only this skin.
