2017-04-05, 13:12
Love this skin. Only reason I don't use it is the lack of views. Specially when browsing addons
Just my opinion. Still using arctic z
(2017-04-03, 16:45)mxlance Wrote: [ -> ]Request: a way to reveal only the fanartI've added the show full fanart mode.
thanks
(2017-04-05, 06:04)jurialmunkey Wrote: [ -> ](2017-04-04, 18:51)bsoriano Wrote: [ -> ]One additional request: Would you consider adding "Artwork" to the context menu for movies and tv shows/seasons/episodes? Performing the same function as the "Artwork" button has in the video info dialog. In this way, I can get all available artwork while browsing movies without having to go into the info dialog for each. Thank you for considering this request.Not possible for a skin to add items to the context menu (there is a hack to do it, but I don't really like doing it). The correct way to do this is through context menu addons and it turns out there is already one for what you want
Settings > Add-ons > Install from repository > Kodi Repo (or all) > Context Menus > Download all artwork - artwork downloader.
There is also "Select Artwork to Download - Artwork Downloader".
There are some really great context menu add-ons in there. I don't think many users know about these add-ons.
The "Play Trailer" and "Skin Shortcuts- Add to menu" ones are really useful, as are the trakt and cinemavision ones if you use those add-ons.
(2017-04-06, 01:01)Blurayx Wrote: [ -> ]@jurialmunkey,Hmm, that is really odd. I'm not sure what could be causing either of those issues. I'm just using Kodi supplied info labels, so it seems strange that they would cause any slowdown. And it looks like the label is putting a new line, but I don't know why either of those labels would. Very strange...
When I set the system info widget, Kodi slows down when viewing system info, And text not displaying correctly.
No issues with my Nvidia Shield TV
(2017-04-07, 15:20)mxlance Wrote: [ -> ]@jurialmunkey,Thanks
Wow, thank you for the Fanart Mode.
It is even better than I imagined.
My wife really likes the skin also. Plan to install it on my other boxes as soon as I can.
Our new favorite skin.
Thanks again for all the work you have put into this skin.
(2017-04-08, 21:22)Edworld Wrote: [ -> ]Jurialmunkey,Hmm, yeah that sounds like a skinhelper bug. It really should give back a blank property if no extrafanart is found (and that would allow the variable to fallback to standard fanart in library) - this is one of the reasons I'm not super keen on using extrafanart because its always more trouble than its worth. I guess the current workaround would be to manual create extrafanart folders where there are none and put the single fanart in there.
If you select to display extrafanart and the movie folder doesn't have an extrafanart folder, nothing is displayed. The fanart.jpg is in the movie folder.Not sure there is a fix for this.
includes_labels file, on widget infoline and label infoline a space is missing after label_duration,,
(2017-04-09, 06:42)jurialmunkey Wrote: [ -> ](2017-04-06, 01:01)Blurayx Wrote: [ -> ]@jurialmunkey,Hmm, that is really odd. I'm not sure what could be causing either of those issues. I'm just using Kodi supplied info labels, so it seems strange that they would cause any slowdown. And it looks like the label is putting a new line, but I don't know why either of those labels would. Very strange...
