Full Version: Party Mode is automatically initiated when trying to play a single song
So, I installed OSMC today and everything is working out fine except this one thing: In the app, when I select a single song (e.g. over the search function) and press "Play", OSMC will display "mixing drinks" or something and then play ten completely random titles, not the one title I requested.
This suspiciously sounds like the party mode, and indeed, it _is_ the party mode that is being activated when I try to play a single song.
Is there any way to prevent this from happening? Either deactivating the party mode as a whole or just changing some settings so that the party mode isn't being activated whenever I select a song.
Something that might be related to the issue, when I try to add any title to the current playlist, an error message will occur saying "invalid params".
Is this a bug or is there anything else you need to know from my system etc?
Thanks in advance.
Jacob
Hi, yes, this is a know bug that should be fixed in the next version.
(2017-03-01, 20:43)syncd Wrote: [ -> ]Hi, yes, this is a know bug that should be fixed in the next version.
Today I installed and set up OSMC 2017.04-1 on my raspberry pi 3 B, and when i was testing everything, the only problem i found was this one. Is there any solution? Or will it be fixed with another update?
I am having the same problem, OSMC and Kore are up-to-date.
This is only a problem when using Kore, not with Yatse or via CEC.
