since the most recent update, TV shows are loading a cropped coverart instead of the banner
using kodi 16.1
pull down the list to refresh the coverart. Let me know if it fixes the issue.
unfortunately that just reloads the cover art
initially when i opened the app last night, the tvshow buttons were blank and it had to load from scratch, and it loaded the coverart instead of the appropriately sized banner
sorry i'm using the wrong term, i was on my phone previously.. it's loading poster.jpg instead of banner.jpg
What happens if you enable "prefer poster for tv shows" option into the kodi host configurations? :?
i'm not seeing that option anywhere? when i searched for it i found your other post from about 5 years ago that mentioned System>Skin>General>TV Shows, but that path doesn't exist.. i can go System>Apperance>Skin>Settings, but no dice on the "prefer poster" option
it was displaying banners properly before the update on march 1st
ahh! found it.. the option within the app.. my bad.. yes the prefer posters option had gotten turned on, thank you so much
glad to know that the issue is solved
