2017-03-04, 19:45
So, I'm running a MINIM8S Android box with Lollipop 5.1.1
I updated Kodi to 17.0, ran Kodi and said first time run and bar moving along the bottom then crashed. Kodi keeps crashing all the time now.
Anyone with any ideas?
tia
EDIT: Log added:
19:53:52.818 T:18446744072287163520 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:53:52.818 T:18446744072287163520 NOTICE: -----------------------------------------------------------------------
19:53:52.818 T:18446744072287163520 NOTICE: Starting Kodi (17.0 Git:20170201-a10c504). Platform: Android ARM 32-bit
19:53:52.818 T:18446744072287163520 NOTICE: Using Release Kodi x32 build
19:53:52.819 T:18446744072287163520 NOTICE: Kodi compiled Feb 1 2017 by GCC 4.9.0 for Android ARM 32-bit API level 21 (API level 21)
19:53:52.819 T:18446744072287163520 NOTICE: Running on amlogic MINIM8S with Android 5.1.1 API level 22, kernel: Linux ARM 64-bit version 3.14.29
19:53:52.819 T:18446744072287163520 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
19:53:52.819 T:18446744072287163520 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
19:53:52.819 T:18446744072287163520 NOTICE: Product: p200_2G, Device: p200_2G, Board: p200_2G - Manufacturer: amlogic, Brand: Android, Model: MINIM8S, Hardware: amlogic
19:53:52.820 T:18446744072287163520 NOTICE: External storage path = /storage/emulated/0; status = ok
19:53:52.820 T:18446744072287163520 NOTICE: ARM Features: Neon enabled
19:53:52.820 T:18446744072287163520 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
19:53:52.820 T:18446744072287163520 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
19:53:52.820 T:18446744072287163520 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-2/lib/arm
19:53:52.820 T:18446744072287163520 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
19:53:52.821 T:18446744072287163520 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
19:53:52.821 T:18446744072287163520 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
19:53:52.821 T:18446744072287163520 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
19:53:52.821 T:18446744072287163520 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
19:53:52.821 T:18446744072287163520 NOTICE: The executable running is: /data/app/org.xbmc.kodi-2/lib/arm/libkodi.so
19:53:52.821 T:18446744072287163520 NOTICE: Local hostname: localhost
19:53:52.821 T:18446744072287163520 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
19:53:52.821 T:18446744072287163520 NOTICE: -----------------------------------------------------------------------
19:53:52.822 T:18446744072287163520 NOTICE: load settings...
19:53:52.866 T:18446744072287163520 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
19:53:52.868 T:18446744072287163520 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
19:53:52.885 T:18446744072287163520 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
19:53:52.887 T:18446744072287163520 DEBUG: Firmware implements AC3 RAW
19:53:52.888 T:18446744072287163520 DEBUG: Firmware implements EAC3 RAW
19:53:52.888 T:18446744072287163520 NOTICE: AML device detected
19:53:52.888 T:18446744072287163520 NOTICE: Found 1 Lists of Devices
19:53:52.888 T:18446744072287163520 NOTICE: Enumerated AUDIOTRACK devices:
19:53:52.888 T:18446744072287163520 NOTICE: Device 1
19:53:52.888 T:18446744072287163520 NOTICE: m_deviceName : AudioTrack
19:53:52.889 T:18446744072287163520 NOTICE: m_displayName : android
19:53:52.889 T:18446744072287163520 NOTICE: m_displayNameExtra: audiotrack
19:53:52.889 T:18446744072287163520 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
19:53:52.889 T:18446744072287163520 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
19:53:52.889 T:18446744072287163520 NOTICE: m_sampleRates : 44100,48000
19:53:52.889 T:18446744072287163520 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_RAW
19:53:52.889 T:18446744072287163520 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3
19:53:52.901 T:18446744072287163520 DEBUG: CSkinSettings: no <skinsettings> tag found
19:53:52.901 T:18446744072287163520 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:53:52.902 T:18446744072287163520 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:53:52.902 T:18446744072287163520 NOTICE: Default Video Player: VideoPlayer
19:53:52.902 T:18446744072287163520 NOTICE: Default Audio Player: paplayer
19:53:52.902 T:18446744072287163520 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:53:52.902 T:18446744072287163520 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:53:52.902 T:18446744072287163520 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:53:52.904 T:18446744072287163520 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:53:52.905 T:18446744072287163520 NOTICE: Loaded playercorefactory configuration
19:53:52.905 T:18446744072287163520 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:53:52.905 T:18446744072287163520 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:53:52.932 T:18446744072287163520 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT idVersion FROM version
tia
EDIT: Log added:
