Full Version: What is the best maintenance tool?
What is the best maintenance tool to use? I want to clean up some files and do a purge... a friend of mine was using something called "RAW" but it keeps giving him an error about it can't update itself, so i'm weary that it's a stable addon to use for myself.
Which one is the most recommended to use?
One that doesn't come from a banned add-on (wiki) repo for a start.
In most cases those things aren't needed at all, and in many can do more harm than good.
Have to do a bit of advertizing Smile
KCleaner
(2017-03-06, 09:24)DaLanik Wrote: [ -> ]Have to do a bit of advertizing Smile
KCleaner
Thanks, it worked perfectly!
rm -r is the best cleaning tool
(2017-03-07, 07:44)fritsch Wrote: [ -> ]rm -r is the best cleaning tool
How do I find that? I tried googling it and it turned up a whole heap of rubbish due to the name of it.
(2017-03-07, 07:53)xdegenerate Wrote: [ -> ]
It's just the Linux command for delete (rm short for remove) recursively
(2017-03-07, 08:01)aptalca Wrote: [ -> ]
Is there a linux command line on android boxes?
It's a joke xdegenerate, don't try and do rm -r
(2017-03-07, 10:05)Mnementh Wrote: [ -> ]It's a joke xdegenerate, don't try and do rm -r
ah, ok, i get ya now. lol
(2017-03-07, 10:03)xdegenerate Wrote: [ -> ]
(2017-03-07, 07:53)xdegenerate Wrote: [ -> ]How do I find that? I tried googling it and it turned up a whole heap of rubbish due to the name of it.
You can probably install a terminal app on Android and it should give you command line access
