Full Version: Creating custom list of movies using a txt or xml file
Hi all
Please bear with me as its my first post and I am not sure where exactly to ask this question Sad
Many times I come across movie lists created on the internet by e.g. imdb users or other random people (or organisations).
Is there anyway to transfer such a list (as a txt or any other format file) to kodi where kodi can tell me which movies from the list I have already watched or which of the movies in the list are missing altogether from my library?
I know tags may serve the purpose but all of that would be manually adding tags to individual movies, which is not very efficient if one wants to create a list of "100 great movies", etc.
Is there an add on for that? I am comfortable with trying advanced, command line settings if you are wondering Smile
Many thanks in advance.
smart_playlists (wiki) are what I use for making these lists.
It was a bit of a pain in the a$$ to create these lists in the beginning, but now I just add the latest winner every year.
The lists are not perfect as some movies have the same names and appear on the lists when I don't want them to, but they are quite accurate.
Excel and Notepad++ are a great help for manipulating text lists from websites.
Here are some to get you started Smile
Academy Award for Best Actor Winners
http://pastebin.com/6iXZdZg7
Academy Award for Best Actress Winners
http://pastebin.com/Ef743KSq
Academy Award for Best Director Winners
http://pastebin.com/dZdv8XUj
Academy Award for Best Picture Winners
http://pastebin.com/e1a8hJJv
IMDB Top 250 (generated automatically from your library data)
http://pastebin.com/YHYdSBDA
Highest Grossing of the year
http://pastebin.com/VmQatyJu
MTV Best Movie
http://pastebin.com/NLqLtv7R
Thanks a lot.
This gives me some idea about how to approach it but unfortunately it doesn't serve the purpose directly, as I will have to create my own lists which is a long process as you mentioned.
I was looking at a more automated approach instead, as there are quite a few sources that I want to follow, and not just imdb.
In any case, thanks again. I might give it a try Smile
Cheers.
If your movie filename is the same as the movie title, and your library is arranged movies/moviename/moviename.mkv for example, I think you could open the list in an editor with regex find/replace support such as Notepad++ and you could convert the movie list into a "dumb" .m3u8 playlist.
scott s.
Thanks Scott
Looks like there's a lot of manual work to be done. Would be much easier if there's a way to create an xml, by just feeding movie titles to it.
Still searching...
Thanks in any case.
