Full Version: Reverse play option
Not sure this is the right forum but i will get started from here.
I'm looking for an option to play my videos in reverse order after i select "Play from here", this option exists in Youtube video addon from playlist where you can choose either "Default" where it goes to the next item in order to play and "Reverse" play option to go previous item once the current video is played.
I searched all over Kodi for this option but doesnt exists.
Appreciate if anyone can guide me on how to use this "Reverse" play option.
I think you would have to reverse the sort order that you're displaying the media in.
(2017-03-06, 23:28)nickr Wrote: [ -> ]I think you would have to reverse the sort order that you're displaying the media in.
I tried that, its not changing anything the sort order
I'm looking for more on the context menu, as soon as you hit "Play from here" then there should be an option to play order "Default" or "Reverse"
We look forward to your code to implement that.
