Full Version: [Release] Shout Factory TV
Pages: 1 2
Place holder. Watch here for news.
Add-on is now available in the kodi.org repo.
Nearly every Gerry Anderson series available, including Thunderbirds in 1080. Secret Agent (Danger Man), The Saint, various old talk shows.
MST3K as well.
Thanks @learningit for this add-on.  It mostly worked for me with LibreELEC 8.2.5 on a Raspberry Pi 2/3.  However I was unable to load the list of Thunderbirds episodes.  After some investigation I discovered the problem was due to a non-ASCII character in one of the episode titles.  Below are the steps to apply a fix.
The following steps assume that you have the Shout Factory TV 3.0.1 video add-on already installed on your Kodi computer.
NOTE: This post has been edited to remove content that is no longer valid.
Happy to find this add-on, no Shout Factory app for Android TV but now I'm watching Super Sentai Zyuranger without having to switch over to a Roku. Thanks!
As I am going over my patched addons, kodiak can you check the Shout TV patch for the indented code issue, thanks
@barney63 this patch had the same problem wherein the code indentation disappeared after I edited the post.  I don't know why this happens sometimes and othertimes not.  Anyways I have re-edited the post to re-introduce the code indentation.
Working now thanks.  Two other patches I have but don't have the addons installed now are HGTV Canada and PBSThinkTV, can you have a look for the indented issue.
Great to have all these fixes so quickly today.
Scraper.py for CBC News, Food Network Canada, Shout Factory TV and TVO are all good, many thanks.
Both HGTV Canada and PBS ThinkTV add-on patches contain the correct indentation so all there should be good to go.  :-)
(2019-10-28, 23:33)kodaksmith Wrote: [ -> ]Both HGTV Canada and PBS ThinkTV add-on patches contain the correct indentation so all there should be good to go.  :-)
Great, thanks!
Getting the "Check the log" error when trying to play something from the TV section.  Strangely, the Film section videos all play ok.  Can some folks check and see if they have the same issue.  Thanks.
Just tested, seems to work fine for me on Windows and Shield.
'Just tested and both movies and TV play properly on Raspberry Pi 3 with LibreELEC 8.2.5 and Kodi 17.6.
Version 4.0.0 available in the Kodi v19 repo.
This version is py3 native and will only run on v19 or above.
Supports Save Movie to Library and Save Series to Library.
FYI:  Recently on my RPi2 running LibreELEC 9.2.1 (Kodi 18.6) I discovered that the Shout Factory TV 3.0.1 add-on no longer lists shows when selecting either Film or TV.
Note that I do not have a Kodi 19 Matrix (Beta) install so have not tested version 4.0 of this add-on.
(2020-08-20, 19:09)kodaksmith Wrote: [ -> ]FYI:  Recently on my RPi2 running LibreELEC 9.2.1 (Kodi 18.6) I discovered that the Shout Factory TV 3.0.1 add-on no longer lists shows when selecting either Film or TV.
The v19 addon is working. I am dropping support for Kodi versions prior to v19 moving forward.
Pages: 1 2
