Full Version: Auto start addon then return to home screen
Hi there. I have looked and can't find the answer so i thought it would be best to ask iin here.
I was wandering wether there was a way to auto start an addon then return to the home screen once its launched.
I have sucessfully got the first part to work using the:
xbmc.executebutin('XBMC.RunAddon(plugin.video.pluginname)') script in autoexec.py but cant get it to return to the home screen.
Can the activatewindow(home) be used as a second command in autoexc.py as im getting a erro when trying this?
or
Can i run/activate the plugin in the background without a gui?
Thanks in advance.
Maddis
Have a posted in the wrong forum?
It would be better in add-on development - I'll move it there.
What's your addon trying to do?
Autostarting the addon and having it run in the background sounds like you want a service addon.
Im using spotify and i want to be able to speed the process up of going into a sub menu withing the plugin (which i am adding as a homeshelf shortcut in amber) rather than having to click on the addon itself and waiting for it to load which takes longer. I was trying to seenifni can run it first before navigating into the plugin
I would like to know how to do this too. Did you figured it out or found another way to launch spotify addon and return back to main screen?
(2017-06-17, 16:30)krul Wrote: [ -> ]I would like to know how to do this too. Did you figured it out or found another way to launch spotify addon and return back to main screen?
I haven't figured this out yet unfortuanatley. Hopefully someone on here can still help
(2017-06-20, 22:18)Maddis Wrote: [ -> ]
import xbmc
xbmc.executebuiltin("RunPlugin(plugin.video.pluginname')", True)
