This in the context of a skin using an addon that lets you change the background image on the home menu. I select change background image > multi-image > and shows some folders, none of which I want to select, so how can I go to the ones I want? The arrow on the top (to go to the upper level folder) only goes as far as within the skin, and I want to select a location outside of it.
Add the locatin as a source and you should be able to enter it
As a "Pictures" source, you mean? Because I'm actually not able to enter the Video sources that I have added either. And I can't seem to be able to add a picture source, entering the picture section doesn't give any listing for "Add Source" (like Video and Music do).
edit: fixed! You were right, I found a menu called "File Manager", added it from there, and now I can.
I was about to direct you to the filemanager.
Glad you already worked it out!
Enjoy
