Full Version: Pi3 Interlace problems
as usual first post and a problem ;-)
I like to watch football/soccer. So i watch a lot of it on S** .
Problem is that it seems that deinterlacing is turned on and off. If you watch the the playingfield in total the interlacing is off, or turns off after a short time. If you see only one or two players on the screen the interlaceing will turn on.
Strange thing is , that sometimes everthing is working ok (eg Championsleague yesterday)
So i took a peek at the streams with Mediainfo
Championsleague (working perfectly)
Video
Menü-ID : 129 (0x81)
Format : AVC
Format/Info : Advanced Video Codec
Format-Profil : High@L4
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 4 frames
Format_Settings_GOP : M=4, N=24
Codec-ID : 27
Dauer : 6 min 28s
Bitrate : 9 062 kb/s
Breite : 1 920 Pixel
Höhe : 1 080 Pixel
Bildseitenverhältnis : 16:9
Bildwiederholungsrate : 25,000 FPS
Standard : Component
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
Scantyp : Interlaced
Scanreihenfolge : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.175
Stream-Größe : 420 MiB (89%)
colour_range : Limited
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
Bundesliga (Interlacing turning on and off)
ideo
Menü-ID : 105 (0x69)
Format : AVC
Format-Profil : Main@L4
Codec-ID : 27
Dauer : 2 h 7 min
Bitrate : 11,0 Mb/s
Höhe : 1 080 Pixel
ColorSpace : YUV
Bits/(Pixel*Frame) : 0.212
Stream-Größe : 9,80 GiB (89%)
I tested with Libreelec 7/8/9 and on 4 different Pi3 and 4 different TVs.
Backend is TVHEADEND.Git 4.2 (ArchLinux on a PC)
Symptoms are on all platforms. So i assume that there is no hardware problem
Hints and suggestions welcome !
Kind Regards,
Alex
Hy White78,
It could be useful for the dev's if you add a debug log of this issue. The Wiki describe how you can create such a debug trace
https://paste.ubuntu.com/24170339/
At 12:44:46 the recorded Bundesligastream starts. This is the one where deinterlacing is crappy !
At 12:46:57.831 the Championsleague recording starts. Deinterlacing is ok !
due to the Debuglogging the streams are a little shaky, but without Debuglogging the streams are ok timewise.
Symptom can be checked if you watch Sky (Germany) Sport News HD. Its FTA !
regards,
Alex
Can you capture a small recording where the deinterlace is not working and post a link (e.g. to google drive or dropbox).
Shure
https://drive.google.com/file/d/0B9k74bZ...sp=sharing
take a look at the text at the bottom !
Thanks in advance !
Alex
(2017-03-13, 19:00)White78 Wrote: [ -> ]take a look at the text at the bottom !
Yes, I can reproduce.
I've got a couple of files where interlace detection isn't as desired for our codec expert to investigate. I'll add yours to the list. Thanks.
Oh thanks!
If there is more I can do , please let me know !
Regards,
Alex
can confirm the problems ... Backends tested TVH and DVBViewer ... LE 7 and 8 on RPI3 (2 different)
Any news about this problem?
Bump! Still no news about the problem ?
Regards,
Alex
Super Ausschnitt, sogar mit Blut und Schlägerei :-)
(sorry, slightly off-topic)
still no news on ths topic ?
Regards,
Alex
Started 2 Years ago and still no solution?
Got the same Problem.
