Full Version: Help please!
I need help, i downloaded kodi and it doesnt work i cant add sources at all it says that device is not connected to internet. And when i go to kodis settings on network everything shows busy, even network. So what should i do? Kodi worked fine before 17.0 came after the update cant use it.....
Well you got up past the splash screen, so you have an operational Kodi without internet access. Perhaps you missed the requester that asked for permission to punch a hole in your firewall for Kodi, check the exceptions list and ensure Kodi has a way through. https://www.sevenforums.com/tutorials/54...ption.html
Moved to support
