Before starting this thread I'd like to mention that this skin wouldn't be here if it wasn't because of the hard work of Pecinko, credits go to him.
As you all probably know Quartz was originally created by Pecinko. After putting all his effort in Quartz 4, version 5 of his skin was born. Up to recently there was a post for Quartz 5 development lead by Pecinko himself. After having seen all this great work I decided to put myself on the development of this skin to. As you can see I've made a fork of Pecinko his skin. To check out the git repository of Pecinko
click here.
So, what to expect from this new thread? In short, you'll find the different links to Git, where you'll be able to download the skin. Next to that the goal is also to get your feedback or possible enhancements I could implement for this skin. I would like to accentuate that I would happily merge other forks into this Quartz version if this is requested. Next to that you'll find different polls etc.
Notice
As you all know Krypton is already there.. currently this skin will only work on Jarvis. Effort is being put in this skin to port it.. any help is greatly appreciated off course. In the meanwhile certainly report any bugs or weird behavior, I'll try to fix those along the way.
Github:
https://github.com/TPX01/skin.quartz.krypton
Latest Krypton release: No stable releases yet
There are multiple versions you can download.
- Master Choose this version if you want to have the latest version of the skin.
Todo
- no new features scheduled until the build is more polished: time to put some effort in all the basic sections that kodi has to offer
Issues
https://github.com/TPX01/skin.quartz.krypton/issues
Did you see a bug? Report it!
Images
watch gallery
Hi I'm so happy you are working on this beauty thanks a lot
few issues I saw while trying the skin
Dialog box to choose the skin not working properly as the yes or no are not aligned I was able to choose only with a mouse
Furthermore in settings video tab doesn't work
Thanks yigo
(2017-03-14, 18:44)Yigo Wrote: [ -> ]Hi I'm so happy you are working on this beauty thanks a lot
Thanks yigo
Thanks Yigo, you're correct! I was busy on fixing the dialog already. Keep reporting the bugs/glitches when you see them. In that way I can build a backlog.
Ok, dialog should be fixed now.. I've only tested a couple of cases where I could find the dialog. Let me know if you found some odd dialog.
Ok my report continues , in your recent version :
1. In settings video and music dialog tab do not work I
2. In the main screen under movies and tv showes the browse button doesnt function
3. When I try to change view type in an add on like from 55 to 52 a dialog box doesn't open
Good day
(2017-03-16, 06:06)Yigo Wrote: [ -> ]Ok my report continues , in your recent version :
Good day
Thanks alot Yigo! You can report all your new bugs/issues by going to following github link:
https://github.com/TPX01/skin.quartz.krypton/issues Just click on 'New issue'.. The main advantage for me is that I can bundle all the issues and ask more information on each of them if needed.
I've added all your comments into the github issues section already..
@Yigo:
Can you answer my question concerning this issue:
https://github.com/TPX01/skin.quartz.krypton/issues/3
The other 2 issues have been fixed and closed!
@All:
Based on what I can see this skin can again be a daily driver in a couple of weeks (top)..
My end goal would be to have a stable skin again so it could be added to the kodi repository. The road to getting there is still long.. So if you see some inconsistencies in the skin flow, report them to please!
I have used Quartz since I first started to use XBMC and it is the only skin I use. I watch some movies and videos but I mainly listen to music and use XBMC/IKodi to display album art. I have messed around with modifying the skin but haven't yet got my brain wrapped around how to do that (and may never get it) but if I were able to modify skins I would like these things.
I would like to see 2 or 3 views in "Full Screen Player" similar to those on Squeezebox Touch. On the Touch there are 4 views that you can toggle through, 1) Album art with song title and artist beside it, 2) Only album art, centered and size maximized, on Squeeze box the aspect ratio of the picture is retained so if a full front and back picture of an album is shown it is not forced into a square display, 3) Equalizer bar for each channel showing the intensities, and 4) VU meters for each channel. The last two are the least important though I do use them occasionally.
Another thing that is missing in the music area, when selecting music using folders to access it, you used to be able to go directly to "Full Screen Player" from the song title by either pressing and holding the enter button and then selecting from the menu or by a left arrow and then selecting from a menu. Currently with Quartz 4 I must browse out to the Home screen to get to the full screen viewer.
Thanks for all you effort on this skin, it is the best.
Mike
Hi , feature request
Could you add the ability to change font size in the Ariel font
I can do it when I go to the font.xml but every update it changes what I did
If we can have this feature it would be great
TIA
Yigo
(2017-03-20, 20:41)mb286 Wrote: [ -> ]made some initial changes on the jarvis version of quartz to make it work in krypton for those still interested, here is a zip : https://github.com/mb286/skin.quartz.kry...master.zip
probably still has (many) issues !
Thanks for your support MB286! Too bad it's a bit late
.. the new link I've provided should already be pretty stable. There are some skins missing on a couple of deeply nested dialogs but nothing big. I'm currently using it as my daily driver and writing down any issues I can find. Feel free to add them to the 'issues' section too if you find them!
(2017-03-21, 01:35)TPX001 Wrote: [ -> ] (2017-03-20, 20:41)mb286 Wrote: [ -> ]made some initial changes on the jarvis version of quartz to make it work in krypton for those still interested, here is a zip : https://github.com/mb286/skin.quartz.kry...master.zip
no problem ! i had a feeling most of what i changed already made in in your own krypton version. simply did not have the time to upload it sooner! i will install your version and give it a spin.
Upcoming week will be quiet busy here but hopefully the week after that should be okay to dig a bit more in solving bugs on Quart for Krypton and Jarvis. Thanks for the feedback on these topics and github.
I'll keep you guys posted!
I don't have much to add other than to say THANK YOU THANK YOU THANK YOU for keeping this skin alive.
