Full Version: Can't launch PC Engine core and games on a RPi2
Hello,
I'm using the latest nightly of Kodi 18 built by Milhouse (March 15th) on my Raspberry Pi 2 and I tried to launch a PC Engine game. To do so I downloaded the "Mednafen SGX" core; I placed some PC Engine games in a folder inside the SD-Card under "~/emulators/PC\ Engine".
Unfortunately when I launch a game I'm getting a black screen. This is part of the logfile:
Quote:21:54:05.881 T:1586492320 ERROR: GetDirectory - Error getting
21:58:11.102 T:1961079552 ERROR: Previous line repeats 2 times.
21:58:11.102 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Could not locate buttonmap "buttonmap.xml"
21:58:11.105 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_fast_cdimagecache
21:58:11.105 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_ocmultiplier
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_nospritelimit
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_hoverscan
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_initial_scanline
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_last_scanline
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_cddavolume
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_adpcmvolume
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_cdpsgvolume
21:58:11.106 T:1961079552 ERROR: AddOnLog: PC Engine SuperGrafx (Mednafen SGX): Unknown setting ID: pce_cdspeed
21:58:11.223 T:1961079552 WARNING: CRenderManager::Configure - queue size too small (2, 6, 1)
I'm getting the same error about missing "buttonmap.xml" with "BlueMSX" and "fMSX" cores as well.
Additionally, BlueMSX reports this error in a popup window:
Quote:The emulator "MSX/SVI/ColecoVision/SG-1000 (blueMSX)" had an internal error
This is the log:
Quote:21:51:12.551 T:1578103712 ERROR: GetDirectory - Error getting
21:51:30.891 T:1961079552 ERROR: Previous line repeats 3 times.
21:51:30.891 T:1961079552 ERROR: AddOnLog: MSX (fMSX): Could not locate buttonmap "buttonmap.xml"
21:51:31.466 T:1961079552 WARNING: CRenderManager::Configure - queue size too small (2, 6, 1)
21:52:22.449 T:1961079552 ERROR: AddOnLog: MSX/SVI/ColecoVision/SG-1000 (blueMSX): Could not locate buttonmap "buttonmap.xml"
21:52:22.460 T:1961079552 ERROR: GAME - LoadGame() - addon 'game.libretro.bluemsx' returned an error: the command failed
21:53:54.336 T:1961079552 ERROR: RetroPlayer: Failed to open file using game.libretro.bluemsx
The other cores I tried are working properly.
Thank you and best regards
This morning I've updated my raspberry Pi to version #315 and I discovered something interesting.
1) After installing and rebooting, I tried to launch a PC Engine game and it worked. I could see the game running and playing it.
2) Then I've tried to launch a MSX game, first with fMSX and then with BlueMSX; but in either cases I had no luck: I got a black screen with fMSX and an internal error with BlueMSX.
3) Then I tried to launch a PC Engine game again, and this time it didn't work anymore... I got a black screen; I tried with the same game that worked on point No. 1 and, again, I got a black screen.
4) I rebooted Kodi
5) I tried to launch the same PC Engine game from point No. 1 and this time, after a reboot, it worked again
6) Then I tried again to launch a MSX game with fMSX and BlueMSX: black screen and internal error
7) Then I tried again with the same PC Engine game and I got a black screen.
I'm no expert but it seems that when I try to launch fMSX and / or BlueMSX with a game, something is breaking...
