Full Version: Scrolling too fast - Can it be customized?
Hi, everyone.
First of all, I would like to thank Kodi Team for their incredible work.
I would like to ask about the problem that I have with scrolling on my laptop concerning Kodi.
Every time I try to scroll either via the touchpad or the mouse wheel, the scrolling is done so quickly that I cannot click on anything. It seems that when I scroll upwards or downwards, after I cross the middle of the screen, scrolling is accelerated in such a way that I cannot click on the stations I like, for instance. The only thing I can do is select via the arrow keys on the keyboard. Is there a way to customize that through Kodi itself or is it the way it generally works?
Thanks in advance.
Deleted.
Quote:I cannot click on the stations I like
Kodi doesn't have stations, 3rd party add-on might; and you didn't elaborate. In these cases, it's likely the 3rd party add-on has written routines that are responsible for this issue, and suggest that you make a direct appeal to the author. Kodi scrolling has been smooth and consistent for me and I can't replicate your issue.
