Full Version: tinyMediaManager First-Timer Question...
Hi. Downloaded, Installed, Performed Settings, Pointed to a Local Source and the lower right Icon of Getting mediaInfo just keeps scrolling back and forth (Windows) and Not Indicating any progress. Has been >14 Hours.
Not sure if I have something improperly set or what.
Would appreciate any help.
Thanks...
ok, it shouldn't take _that_ long Smile
You might want to close & reopen TMM and try an update again.
If it still happens, check the tmm.log logfile, if it stops at the same file...
Hi Myron and thanks for the quick reply.
I have closed and reopened a number of times.
Below are the Errors reported:
06:56:26.392 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_fanarttv.conf' - using defaults
06:56:26.587 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
06:56:26.595 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
06:56:26.603 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.atmovies.com.tw.conf' - using defaults
06:56:26.603 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.musicvideos.theaudiodb.com.conf' - using defaults
06:56:26.611 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
06:56:26.619 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
06:56:26.626 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvshows.themoviedb.org.conf' - using defaults
06:56:26.634 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.universal.conf' - using defaults
06:56:26.634 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
06:56:26.642 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
06:56:26.650 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
06:56:26.650 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
06:56:26.845 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_moviemeter.conf' - using defaults
06:56:26.853 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_opensubtitles.conf' - using defaults
06:56:26.970 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_tmdb.conf' - using defaults
nah, these are just warnings.
Please upload the complete logfile somewhere; maybe we see something Smile
