Full Version: XBMC Lyrics Script enhancement suggestion
1) I would love it if you could change the star rating on a song while you are in XBMC lyrics. Right now I have to exit lyrics, rate the song, then go back to lyrics.
2) I would love it if instead of choosing which lyrics server to use, I could choose my preferred one. Then it would check my preferred one first, if it can't find a match, check the other one, if it STILL can't find a match, then give me a list of choices, or say artist not found, or whatever. Everytime lyrics for a song aren't found I just switch the lyrics server right away anyway.
The lyrics script isn't supported by team XBMC, so you should probably ask this in the script section
Though not supprted - it would be great to go to lyrics from a song in play via the title or info sub-menus
