2017-03-22, 15:24
2017-03-22, 20:19
same here
2017-03-22, 21:26
I'm not sure what happened titan on my laptop running17.0 is going fine but firestick and mxq box not working properly on 16.1 but when I downgrade to 16.0 on laptop it's been running fine
2017-03-23, 00:04
They have change the way the home menu (global) widget work at least at the 17 version of Kodi.
You need to set the layout (appearance) as the previous old version from
"Homescreen layout"
and later go to
"configure shortcuts" / "edit menu shortcuts"
at the first menu shortcut/command (button you have set) go at the "widget" and select it (it's at the middle screen menu) and add the widgets you want at the home screen.
If you want to always have this widget at the home menu and not change as you scroll at the sidebar of the home menu bar go at
"homescreen layout" and select "show all widget (detack from main menu focus)" as on
and also remove all the extra widget from the rest of the sidebar commands/buttons at
"configure shortcuts" / "edit menu shortcuts" like the widget at settings button for example etc
"Homescreen layout"
and later go to
2017-03-23, 13:53
I'm having this same issue and can't fix it
2017-03-28, 00:17
You will have to reset your menu shortcuts to defaults and start over or try to correct it yourself by using the shortcuts editor.
