2017-03-25, 03:27
Kodi 16.1 installed since end of 2015 on Kubuntu 15.10.
Starting earlier this week, open Kodi, click on anything that connects to Internet, Kodi crashes / disappears.
History on what I tried: I removed some repositories and add-os of which I only have a handful. Same thing. Researching I found reference to System/Settings/Add-ons/System/Dependencies/URLResolver which seemed up-to-date but I tried clicking on a previous version then update again. It would crash when I try to update and auto-update didn't work either. I tried removing .kodi/guisettings.xml which didn't help. I tried upgrading Kodi to 17 then to nightly builds both of which, when opening kodi, would freeze and crash quickly. So I downgraded back to 16.1 with the same issues.
I upgraded the Linux OS to Kubuntu/Ubuntu 16.04, the URLResolver auto-updated & RSS was working on the bottom but it still crashes clicking on anything external such as trying to see a YouTube video though internally playing a video file still works.
On this forum, someone said about removing "Addons27.db" which I found in .kodi/userdata/Database, this file was empty 0B but I renamed it anyways and tried again, same.
I hope someone can help me fix this. I haven't found where I can upload the crashlog so I copied in part of it where I saw errors.
############ END Kodi CRASH LOG #############
[/quote]
Quote:############## Kodi CRASH LOG ############################## END LOG FILE ################
################ SYSTEM INFO ################
Date: Fri Mar 24 20:42:12 EDT 2017
Kodi Options:
Arch: x86_64
Kernel: Linux 4.4.0-66-generic #87-Ubuntu SMP Fri Mar 3 15:29:05 UTC 2017
Release: Ubuntu 16.04.2 LTS (Xenial Xerus)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/tv/core (2017-03-24 20:42:12.410680175 -0400)
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007fe4e4121fc9 in RAND_bytes () from /lib/x86_64-linux-gnu/libcrypto.so.1.0.0
[Current thread is 1 (Thread 0x7fe489ffb700 (LWP 6847))]
Thread 24 (Thread 0x7fe4717fa700 (LWP 6884)):
#0 __lll_lock_wait_private () at ../sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:95
#1 0x00007fe4e4767f84 in ___fprintf_chk (fp=0x7fe4e4a17770 <_IO_stdfile_2_lock>, flag=1, format=0x7fe4703b5088 "extern \"Python\": function %s() called, but %s. Returning 0.\n") at fprintf_chk.c:30
#2 0x00007fe4703ae1af in ?? () from /usr/lib/python2.7/dist-packages/_cffi_backend.x86_64-linux-gnu.so
#3 0x00007fe4707211ac in ?? () from /usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/_openssl.x86_64-linux-gnu.so
#4 0x00007fe4cacdae5d in ?? () from /usr/lib/x86_64-linux-gnu/libcurl.so.4
20:41:10 T:140621188180288 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
20:41:10 T:140621188180288 NOTICE: Host CPU: Intel® Core i5-4460 CPU @ 3.20GHz, 4 cores available
20:41:10 T:140621188180288 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:41:10 T:140621188180288 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:41:10 T:140621188180288 NOTICE: special://masterprofile/ is mapped to: /home/tv/.kodi/userdata
20:41:10 T:140621188180288 NOTICE: special://home/ is mapped to: /home/tv/.kodi
20:41:10 T:140621188180288 NOTICE: special://temp/ is mapped to: /home/tv/.kodi/temp
20:41:10 T:140621188180288 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:41:10 T:140621188180288 NOTICE: Local hostname: tv
20:41:10 T:140621188180288 NOTICE: Log File is located: /home/tv/.kodi/temp/kodi.log
20:41:10 T:140621188180288 NOTICE: -----------------------------------------------------------------------
20:41:10 T:140621188180288 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanSuspend'
20:41:10 T:140621188180288 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'CanHibernate'
20:41:10 T:140621188180288 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property 'OnLowBattery'
20:41:10 T:140621188180288 NOTICE: load settings...
GL_ARB_shader_clock GL_EXT_shader_samples_identical
20:41:10 T:140621188180288 ERROR: Unable to load libcec.so.3.0, reason: libcec.so.3.0: cannot open shared object file: No such file or directory
20:41:10 T:140621188180288 ERROR: Initialise - failed to initialise bus cec
20:41:10 T:140621188180288 NOTICE: Running database version Addons20
20:41:10 T:140621188180288 NOTICE: Running database version ViewModes6
20:41:10 T:140621188180288 NOTICE: Running database version Textures13
20:41:10 T:140621188180288 NOTICE: Running database version MyMusic56
20:41:10 T:140621188180288 NOTICE: Running database version MyVideos99
20:41:10 T:140621188180288 NOTICE: Running database version TV29
20:41:10 T:140621188180288 NOTICE: Running database version Epg11
20:41:10 T:140621188180288 NOTICE: start dvd mediatype detection
20:41:11 T:140621188180288 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:41:11 T:140621188180288 NOTICE: ActiveAE DSP - starting
20:41:11 T:140621188180288 NOTICE: initialize done
20:41:11 T:140621188180288 NOTICE: Running the application...
20:41:11 T:140621188180288 NOTICE: starting zeroconf publishing
20:41:11 T:140621188180288 NOTICE: starting upnp client
20:41:11 T:140619158640384 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
20:41:11 T:140619158640384 NOTICE: UDP: Listening on port 9777
20:41:11 T:140620198807296 NOTICE: [plugin.video.youtube] Startup: detected Jarvis (Kodi-16.1), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = False
20:41:13 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:13 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/xbmc
20:41:20 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:20 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/xbmc
20:41:27 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:27 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/xbmc
20:41:27 T:140620589020928 ERROR: Unable to obtain rss feed: http://feeds.xbmc.org/xbmc
20:41:28 T:140620198807296 NOTICE: [plugin.video.youtube] Running: YouTube (5.3.12) on Jarvis (Kodi-16.1) with Python 2.7.12
20:41:29 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:29 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/latest_xbmc_addons
20:41:33 T:140619133462272 NOTICE: [plugin.video.youtube] Running: YouTube (5.3.12) on Jarvis (Kodi-16.1) with Python 2.7.12
20:41:36 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:36 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/latest_xbmc_addons
20:41:36 T:140619133462272 ERROR: /home/tv/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/connectionpool.py:843: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest...l-warnings
InsecureRequestWarning)
20:41:43 T:140620589020928 ERROR: Previous line repeats 2 times.
20:41:43 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:43 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/latest_xbmc_addons
20:41:43 T:140620589020928 ERROR: Unable to obtain rss feed: http://feeds.xbmc.org/latest_xbmc_addons
20:41:45 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:45 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/updated_xbmc_addons
20:41:52 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:52 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/updated_xbmc_addons
20:41:59 T:140620589020928 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:41:59 T:140620589020928 ERROR: CCurlFile::Open failed with code 0 for http://feeds.xbmc.org/updated_xbmc_addons
20:41:59 T:140620589020928 ERROR: Unable to obtain rss feed: http://feeds.xbmc.org/updated_xbmc_addons
[/quote]
