As far as I see it, the library node editor addon can create custom main menu items easily. The question is why Estuary does not support that, while it supports the addong for adding subitems in the already defined main menu entries ? Is such support planned ?
Anyone ? ... at least a simple "Not planned" or something ?
Its too slow basically.
You could just edit the skin file if you want.
(2017-04-05, 10:03)docwra Wrote: [ -> ]Its too slow basically.
... but I'll lose the changes on every update, right ? Besides, by "slow" you mean slow to create the items, I guess ? This should not be an issue, having that eventually you set this once and awhile. Slow to run can't be true, since the inner items are handled by this very same approach.
Must say I'm also very confused with this one.
With Estuary comes the possibility to edit the menu categories, which leads to automatically trigger the installation of Library Node Editor addon.
Not being able to add the desired menu entries makes no sense then.
