Full Version: New version of KODI not launching - posted log
Hi there, hopefully I copied this correctly. Haven't used pastebin before and had NO idea I had a hidden Library in my Mac Smile
My new version of KODI keeps running through the same process. Saying it quit unexpectedly and can't open.
I've deleted it to trash and did a search through the other library files to see if there was anything else with KODI in it, and there isn't.
Hoping you can assist:
https://pastebin.com/Utm16EWT
Thanks,
Tera
  • Go to /Users/<your_user_name>/Library/Application Support/Kodi/userdata/Database
  • Backup all Addons*.db files somewhere else
  • Delete them at the given location
  • Try to start Kodi
If that helps - provide me all addons*.db files via dropbox for example.
Solved in my post
