Full Version: dailogaddoninfo.xml auto update
So I figured out the label... But when using sendclick(13) nothing happens. Even tried sendclick(9000,13).... And ideas? Is there another way to toggle the update setting ... If I use skinhelper.. then what would I use in system.getbool()?
Thank for the help
DialogAddonInfo ID is 146
So the send click command would be
SendClick(146,13)
Reference:
Window_IDs (wiki)
EDIT: but sendclick doesn't appear to work on radiobuttons.
Is there a way to at least change the label... It seems this one radiobutton is locked down I can't change anything about it .
