2017-04-26, 14:29
2017-04-26, 18:35
The skin is out!
Repository
https://github.com/Tgxcorporation/skin.andromeda
Installation
https://github.com/Tgxcorporation/skin.a...rom-Github
https://github.com/Tgxcorporation/skin.andromeda/wiki
Todo
Repository
Installation
Todo
- Script Extended Info
- Global Search
- Next Aired
- Weather
- Additional fonts
2017-04-27, 09:14
great!
2017-04-27, 09:32
almost perfect little request add Arial font and make info for movie or tvshow appear when osd pause thnx
2017-04-28, 02:44
This is very nice. But I think it needs some changes to make it perfect.
1. In the initial menu, the background of movie tabs, series, etc ... should have a background color, because sometimes the background letters are not read.
2. When choosing the information of a movie, you should have a button to view the movie. In this topic you should go to a column that is hidden, I think that should improve.
3. The osd should be more elegant. It should copy or inspire in Arctic Zephyr.
2017-04-28, 09:05
Thanks, i'll try to improve the skin.
Tgx
Tgx
2017-04-28, 13:13
Love the skin... But for some add-ons I get "add-on has been marked broken in repository" message. And I wasn't able to install, after putting my sources and and after downloading the repo. I went to install from repository. I get that message.
2017-04-28, 13:48
Should be fixed in the latest revision.
Tgx
Tgx
2017-04-28, 14:04
(2017-04-28, 13:48)Tgxcorporation Wrote: [ -> ]Should be fixed in the latest revision.
Tgx
Ok thanks. Is there a way to turn off the option to when scrolling all the way up for example... On home screen, when going all the way up, you get the weather and settings, favorite, and power option. That's fine. But when on, let's say your searching for a tv episode, when your all the way to the bottom of the list. It goes back on the top of the list. When pressing up again it opens up the option for setting weather ECT. I want to turn that off. I have a habit of pressing up to go back to the bottom of the list again just in case I've missed what I'm looking for. Or have the highlighted bar focus in the middle so I would know when I almost reached the bottom of the list.
2017-04-28, 14:07
I'll work on it
Tgx
Tgx
2017-04-30, 21:51
Wow! What an impressive piece of work this is. It looks and feels like a professionally done interface. I'm not personally a fan of horizontal style menus or else I'd use this skin without question.
2017-05-01, 04:14
Hello my italian brother
Breath taking skin!
Im passionate about your design for elegance & simplicy!
I suggest you create a suggestion thread to keep users
informed on whats accepted and what not.
And a thread just for tracking bugs.
If impossible here on this forum just create yours
Your on tweeter?
Thats a good media for having followers
Track you & your skin progress!
Got some suggestions coming up for you,
Just need more time to get my stuff together
Hope people will make this skin THE SKIN to use on kodi!
Breath taking skin!
Your on tweeter?
2017-05-01, 12:41
2017-05-01, 15:19
(2017-05-01, 04:14)eskro Wrote: [ -> ]Hello my italian brother![]()
Breath taking skin!
If impossible here on this forum just create yours![]()
Your on tweeter?
Thanks for your kind words!
Tgx
2017-05-01, 22:50
